ATTS When does it work?
Old Mar 14, 2006 | 08:42 PM
Coroner's Avatar
Default ATTS When does it work?
My prelude is for sure a Type SH but my atts light never goes on. How do I know when my atts is kicking in. Am i missing something?
Old Mar 14, 2006 | 08:58 PM
lude98SH's Avatar
Default Re: ATTS When does it work? (Coroner)
The light should come on for a few seconds when you start your car.
Old Mar 14, 2006 | 09:01 PM
Coroner's Avatar
Default Re: ATTS When does it work? (lude98SH)
well yea it comes on when i start it up but when will the atts light turn on when i'm driving because mine never has no matter how manny sharp turns or hard corners i've taken.
Old Mar 14, 2006 | 09:03 PM
dumkopf's Avatar
Why shoud it come on? Wouldn't it coming on imply that there's something wrong with it?
vinuneuro's Avatar
If the light is on while driving, there is some kind of fault. It only works while turning. The amount to which it transfers torque to one side is dependent on factors such as vehicle speed, steering angle, lateral-g, yaw, etc. During normal driving you don't feel it too much, but if you push the car some it quickly becomes clear because there is virtually no understeer, plenty of vehicle rotation.
Old Mar 14, 2006 | 09:04 PM
99JDMTypeS's Avatar
It's not suppose to come on dude. If the light was to ever come on that means there is something wrong with the ATTS unit. Whenever the light is on the ATTS unit is completely shut off into safe mode so nothing else will get damaged through the ECM.
Old Mar 14, 2006 | 09:05 PM
Coroner's Avatar
Default Re: (dumkopf)
oh is that the only reason why it would come on? Because i was reading the owners manuel and it says it will flash on while taking hard corners.
Old Mar 14, 2006 | 09:07 PM
99JDMTypeS's Avatar
Default Re: (Coroner)
No it will never flash. If the indicator light ever comes on the ECM is throwing some sort of code saying that there is a problem with the unit.
Old Mar 14, 2006 | 09:16 PM
lude98SH's Avatar
Default Re: (99JDMTypeS)
Yea you shouldnt really "feel" it, its not a thing where you should really feel it kick in. But if have have ever driven a base you will feel there is alot less understeer. Most likely if your atts unit was having any problems you would get a cel.
Old Mar 14, 2006 | 09:19 PM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99JDMTypeS &raquo;</TD></TR><TR><TD CLASS="quote">No it will never flash. If the indicator light ever comes on the ECM is throwing some sort of code saying that there is a problem with the unit.</TD></TR></TABLE>
Well actually this is only somewhat true. Atts is tied in with some other things. I know that if your o2 sensors throw a code you will get a check engine light along will an Atts light, even though there is nothing wrong with the unit. Im pretty sure this puts the system into limp mode. But basicly what im saying is that just because you may have an atts light it doesnt necessarily mean that the problem lies in the atts unit.
microfunk5
Honda Civic (2001 - 2005)
Mar 8, 2010 09:49 AM
Markov
Jan 25, 2006 10:13 AM
Try2Live4God
Acura TL, RL & ZDX
Nov 30, 2005 04:21 PM
P3T3R
Apr 17, 2005 09:36 PM
IntegraZ
Sep 16, 2001 09:19 PM
