Engine preparations for possible JRSC?
Old Mar 13, 2006 | 01:12 PM
joeboxer212's Avatar
Default Engine preparations for possible JRSC?
I might go with a JRSC in a few months. Aside from fuel management, what can I specifically do to my stock engine to make it run safer? I burn a lot of oil so that's my main concern. Should I install the charger and wait until it blows? Or are there things I can do now to make my engine stronger/healthier before I put on the charger. I've researched a bit and it seems that 6psi belt on a stock engine is fine. How about a 9 psi belt on a stock engine with 550 injectors and good fuel management? Like I said, I burnt 4 qts in the last 5,500 miles recently. Does this sound like a bad idea for a charger? Also, going to do a compression/leak test soon if that should help me make my decision.
Old Mar 13, 2006 | 01:19 PM
97h22a9's Avatar
most people say over 7psi on stck block is bad but others say its all about the tune.
jrsc has heating issues whenever you up the psi.
i would check your compression and stuff, 4qts is alot of oil, ludes do burn alot of oil but i dont know about that much, wouldnt suprise me tho.
good fuel management and a good tune is key to any f1 from whta ive been reading.
i would install the jrsc and later down the road sleeve the cylinders and all that good stuff, but if you choose to build the block your looking at a good chunk of change.
also prospeed custom makes pulleys for the jrsc
beat
Apr 25, 2014 08:31 PM
Zwackelmann
Jun 15, 2004 12:00 PM
eXcelonTypeR
Mar 21, 2004 10:28 PM
LostLude
May 3, 2003 10:21 PM
KooK
Jun 11, 2002 07:23 AM
