Overheating problems!!! Please HELP
Old Mar 11, 2006 | 06:49 PM
Bulldogg83's Avatar
Default Overheating problems!!! Please HELP
Alright guys....here's the deal....I have a 92 Prelude that I have been driving and tonight on the way over to my gf house it just started overheating. After letting the car cool down for a while, I went outside and checked over a few things. I first checked the coolant level and everything there was ok. Than I checked for any leaks and there were absolutly none to be found. After that I pulled all the spark plugs and checked to see if there was any coolant on them and there was none. Cyl 3 and 4 were a little wet, but there were no signs of a blown headgasket to be found. I did a compression check on the motor just to see if the headgasket could be blown and everything came out 200-210 across the board. After that I checked around the timing belt cover to see if there was any leaking from the water pump and I couldn't see any. So at this time I am a little perplexed as to what the issue could be. I am open to any suggestions.
Old Mar 11, 2006 | 07:20 PM
ThE PiMpiN Co's Avatar
Default Re: Overheating problems!!! Please HELP (Bulldogg83)
thermostat
Old Mar 11, 2006 | 07:34 PM
hondamanmark's Avatar
^^^^^ si or if not that.....small hose leak.....if not that......save up and get Koyo Race radiator like i did
Old Mar 12, 2006 | 08:24 AM
Bulldogg83's Avatar
Default Re: (hondamanmark)
Checked the hoses while the car is running and gave the car gas by pushing on throttle cable and saw no leaks. Checked the thermostat this morning and it's fine. Could it be the water pump?
Old Mar 12, 2006 | 08:39 AM
Default Re: (Bulldogg83)
check your coolant level in the radiator again, and bleed the coolant system. check for leaks too and tell us what happens.
Old Mar 12, 2006 | 10:04 AM
Bulldogg83's Avatar
Default Re: (ThE PiMpiN Co)
Went ahead and replaced thermostat. Before doing so coolant levels were still fine. Changed it, refilled and bled system, and car is still overheating. Check all hoses for leaks and can not find a single one. This is confusing the hell out of me.
Old Mar 12, 2006 | 10:27 AM
satsilprelude's Avatar
is fan coming on? if not could be relay
Old Mar 12, 2006 | 11:02 AM
Bulldogg83's Avatar
Default Re: Overheating problems!!! Please HELP (satsilprelude)
Fan kicks on just fine
Old Mar 20, 2006 | 03:17 PM
Kusai.Nihonjin.Desu's Avatar
Updates?
Old Mar 20, 2006 | 03:53 PM
preludeSleeper's Avatar
if you have high milage it is possible it could be the water pump. the impellars often rust away and just stop moving water through the block causing overheating. if you change that you may as well change the timing belt and put some skunk 2 racing cam gears in while your all up in the timing cover. other problems could be with the coolant temperature sensor. best way to find out is to put it on a scanner and run data streem. check the sensor output readings verse the dash reading make sure it is reading right. another possibility is a air pocket but bleeding should have cleered that up. make sure your fan shroud isnt cracked also cuz that can cause overheating. rust in the radiator also can cause flow problems and overheating. try flushing the sytem get all the garbage out to make sure there are no restrictions. a bad radiator cap seal can cause pressure loss and also result in poor coolant flow. if it was me i would just change the water pump thermostat cool temp sensor rad cap and flush the system. the parts arent that costly and probably need changing anyway. plus this would elimitate all flow problem possibilities.
Old Mar 20, 2006 | 04:17 PM
SiB16A's Avatar
try switching out radiator.. i had this problem once and ended up changing head gasket for nothing.. it was just the radiator... try it b4 u do headgasket
Old Mar 20, 2006 | 07:17 PM
darockstar's Avatar
i jus changed the cap on my old h23 and never had problems again...5 dollar fix
Old Mar 20, 2006 | 09:41 PM
PrettyLude's Avatar
check to see if if both hoses to the radiator are hot, sometimes the radiator itself can get clogged up
Belvedere
16
Jul 13, 2011 08:56 AM
Doylerules4588
11
Jul 3, 2008 08:01 PM
Bulldogg83
Mar 22, 2006 09:24 AM
Polish_dude
Mar 4, 2006 12:15 PM
Mohsin
Apr 27, 2005 08:01 AM
