tb problem..... need help!
Old Mar 13, 2006 | 11:14 PM
lude-tec's Avatar
Default tb problem..... need help!
hello people, need your help! im having trouble with my idling. before i cleaned my tb my idle is at 700-800 now after i cleaned the tb, it started to idle at 900-1000. what could be the problem? btw i didnt took it out i just sprayed some carb cleaner then used some q-tips and paper towel to wipe the grime and some i couldnt reach. thanks in advance.
Old Mar 14, 2006 | 12:50 AM
prelude1897's Avatar
Default Re: tb problem..... need help! (lude-tec)
Clean your EGR and IAC valves
Old Mar 14, 2006 | 05:43 AM
pentaq's Avatar
Default Re: tb problem..... need help! (prelude1897)
Your idle is higher because you cleaned some **** and your car is getting more air than before. There's a screw on TB- turn it clockwise (unplug IAC before) as you reach proper idle and after that reset the ECU.
Old Mar 14, 2006 | 08:01 AM
lude-tec's Avatar
Default Re: tb problem..... need help! (pentaq)
thanks for the replies. btw why do i have to unplug the IAC before adjusting the idling screw? thanks
Old Mar 14, 2006 | 02:24 PM
lude-tec's Avatar
anyone else?
Old Mar 14, 2006 | 04:03 PM
darkspector's Avatar
I believe it controls the amount of air at idle... so with it plugged in it will make it's own corrections. Voiding the adjustments ou have just made.
Old Mar 14, 2006 | 04:20 PM
slammed95lude's Avatar
Default Re: (darkspector)
Please tell me you didn't do this while it was running, because if you did you leaned the car out, thats bad and your pistons will hate you. If not it will idle high for a little while, just because of the high combustabilty of the cleaner. also clean out your EGR ports.
Old Mar 14, 2006 | 04:29 PM
ed_1's Avatar
Default Re: (slammed95lude)
Just adjust the screw next to the tb, like others said, i had this same issue with mine, and let the car warm up to operating temperature, and than get a flat head screwdriver and listen/look at the rpms. If that doesn't work than is most likely your IACV. I didn't disconnect mine when i adjusted it.
Old Mar 14, 2006 | 08:03 PM
Honda Sport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude-tec &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the replies. btw why do i have to unplug the IAC before adjusting the idling screw? thanks</TD></TR></TABLE>
yes you do. if you look in a helms manual, you disconnect the iacv, adjust the idle, reset the ecu. you're good to go.
downshift3r
Sep 30, 2013 06:34 AM
VTechLivin94
15
Mar 29, 2013 06:52 AM
deb1991
Aug 14, 2011 11:03 AM
accord9t3
Nov 15, 2004 09:47 AM
