Clutch problems
Old Oct 30, 2006 | 07:52 PM
k_lude's Avatar
Default Clutch problems
my clutch makes noises and my car or motor seems like its shaking alot...like the clutch is scrapping the car...i got a six puck no springs with a 8 or 12lb flywheel sometimes when im barely letting of the clutch it scrapes and you can feel the clutch on the foot shaking and it gets softer....can someone please help??
Old Oct 30, 2006 | 07:59 PM
GraphiteMW's Avatar
Default Re: Clutch problems (k_lude)
Get a new clutch.
Old Oct 30, 2006 | 08:04 PM
k_lude's Avatar
Default Re: Clutch problems (GraphiteMW)
the problem is its happen before and after i got a new clutch....are there any bearings that might go bad or is it the flywheel maybe?
Old Oct 31, 2006 | 07:00 AM
Dangger's Avatar
throwout bearing..... you should have already replaced it when you got your new clutch.
do a complete clutch fluid change.... I don't think ludes have pilot bearings on the flywheel..
oh yea... you also should've had your flywheel resurfaced if you're using an old one.
Old Oct 31, 2006 | 11:08 AM
94Vtecluder's Avatar
Default Re: (Dangger)
Ya might be your throwout bearing or maybe your flywheel is warped.
Old Oct 31, 2006 | 11:27 AM
k_lude's Avatar
Default Re: (94Vtecluder)
its a new flywheel...can it go bad so easily??isnt the throw out bearing in between the flywheel and the clutch??can i still drive it???can anything go wrong at anytime??were can i get one and are there any high performance ones??? sorry for all the questions...i just want to be on the safe side....
vtechatch
Sep 25, 2007 09:17 PM
mikejr83
May 22, 2007 12:24 PM
sixtodc2
Jul 3, 2006 04:52 AM
allmotor99lude
Jul 7, 2005 08:01 PM
BigBadBuford
Oct 22, 2003 08:34 AM
