driver side headlight (searched)
Old Oct 28, 2006 | 09:52 PM
Brown-tec's Avatar
Default driver side headlight (searched)
hey i have a 98 lude and my driver side headlight went out tonight, ive been reading on some archived posts and alot of people's passenger headlight has gone out many times, i figured i have the same problem but on the driver side. i use silverstars and on those posts they have said that silverstars dont last that long and usually one lasts longer than the other, well i bought 2 of them and the dirver went out, tehn i replaced that one, then it went out again, this will be my 3rd time replacing the driver side light! the passenger side one is fine, i didnt touch the bulb with my finger during installation im really careful about that, so what could it be? any suggesstions would be greatly appreciated.
Old Oct 29, 2006 | 02:49 AM
Duane_in_Japan's Avatar
Default Re: driver side headlight (Brown-tec)
You may have a bad ground connection or one of your wires is frayed causing the circuit to overheat, I am thinking that both lights use the same ground and that would not be your problem, sorry, dont have a wire diagram in front of me.
See if the connector to the bulb looks melted, compare both sides.
Old Oct 29, 2006 | 10:48 AM
Brown-tec's Avatar
Default Re: driver side headlight (Duane_in_Japan)
ok thnx im will check that today and post the results
frost_0ne
Jan 25, 2009 08:19 PM
otsegolectric
Jul 22, 2008 10:47 AM
Sic_DA_Nine
Lighting
Apr 2, 2008 02:37 PM
gold_ef
Oct 20, 2006 02:43 PM
Accorddrver
Apr 27, 2004 09:41 AM
