fuel problem?
Old Nov 3, 2006 | 08:41 AM
94siludeturbo's Avatar
Default fuel problem?
when i start the car its fine.....when i run for about 20 mins it seems to miss every once in a while then all of a sudden the car will die........i give it more gas and the rpm continue to go down....down shift to keep the rpms up and my start the engine back up and nothing.....had it trailered home and the next day started right up....so i took it back and the same thing happens........check the plugs seems to be lean (white in color) so im thinkin it will be a fuel problem....any ideas what it could be....fuel pump maybe?
Car is a 1994 prelude si
side note. wondering if its ODB 1 or 2 i have a ecu from a 92 prelude si
any input would be of much help
Old Nov 3, 2006 | 11:09 AM
doubledeucehatch's Avatar
Its OBD1
Old Nov 3, 2006 | 01:57 PM
lude98SH's Avatar
Default Re: (prelude252)
Did you get any codes ?
Old Nov 3, 2006 | 06:41 PM
JasonST's Avatar
Default Re: (lude98SH)
Yeah is ur check engine light on? Don't run it too long running lean, that's bad for ur engine, u might burn a valve or 2.
408h22a1
Feb 28, 2013 11:36 PM
oneprelude
Jan 12, 2010 09:52 PM
zsudz922
Jan 9, 2008 07:49 AM
JohnD1079
Jan 9, 2007 05:26 PM
scribner
Nov 26, 2002 05:09 PM
