Upgrading grounds
Old Oct 25, 2006 | 08:24 PM
kornerk12's Avatar
Default Upgrading grounds
Ok I am going to upgrade the grounds probably fri or saturday. How many are there exactly so I know how much wire to buy.
I believe there is:
1. Valve Cover
2. Thermo
3. Trans
4. Battery
Is that all the grounds ?
Also is there anything to remember when doing this ? 4 guage wire and some ring connectors crimped should be ok for this correct ?
Old Oct 25, 2006 | 08:27 PM
M2B4's Avatar
Default Re: Upgrading grounds (kornerk12)
dude there was a guy @ the local h-t meet who had like some 0 gauge or 1/0 as his tranny ground lol
Old Oct 25, 2006 | 08:54 PM
Hawkze_2.3's Avatar
Go to an auto parts store and get some already made battery cables for like $3-4 each. They have some that are badass quality and heavy duty with thick ring connectors on each end (not battery terminal connectors). I recently did mine this way.
I did: cylinder head to frame, tranny to frame, and IM to frame. Sand the sh*t out of all the connections and make sure all threads of bolts and holes are clean.
Old Oct 25, 2006 | 09:39 PM
InvaderTrax's Avatar
So far the only one I've done was my valve cover. I had to cut it when I put in my cam gears, so I replaced that grount. I ran some 12 gauge wire from the rear vc nut to where another ground meets the frame. Couldn't tell you if I picked up any power. If I did, it was like 1-2hp
Old Oct 27, 2006 | 07:27 AM
kornerk12's Avatar
Default Re: (InvaderTrax)
I got 10 guage and the stock ground looks like its alittle larger.
Old Nov 7, 2006 | 11:44 AM
kornerk12's Avatar
Default Re: (kornerk12)
I ended up using 8 gauge on the valve cover. But where do find ring connectors for the 1 gauge for the battery ground and trans ground ?
Old Nov 7, 2006 | 12:02 PM
GraphiteMW's Avatar
How are those ground kits on ebay?
Modified by GraphiteMW at 1:19 PM 11/7/2006
Old Nov 7, 2006 | 02:16 PM
esedulerp5tenin's Avatar
Default Re: (GraphiteMW)
you forgot the starter
Old Nov 7, 2006 | 03:19 PM
DIRTYsouthBB6's Avatar
I replaced all of the three ground wires coming off of the valve cover with 2-gauge wires, replaced the transmission ground wire with a Tsunami 4-gauge wire, and replaced the ground coming off of the negative battery terminal with a 2-gauge and a 4-gauge Tsunami wire.
Old Nov 7, 2006 | 03:29 PM
kornerk12's Avatar
Default Re: (DIRTYsouthBB6)
What did you use for your connections ?
Old Nov 7, 2006 | 03:32 PM
Revi's Avatar
Doesnt Hyperground make a 5g kit?
Old Nov 7, 2006 | 07:45 PM
kornerk12's Avatar
Default Re: (DOHCtor-S)
Yes but im making them. I dont wanna pay $100+ for ground wires.
Old Nov 7, 2006 | 08:49 PM
TheWalrus's Avatar
be sure not to run any new ground wires near from the ign coil...you will LOSE a bit of power if you do. the thermostat grond is the most important besides the batt imo...i used 4 gauge there and 8 gauge on the others
Old Nov 7, 2006 | 09:00 PM
kornerk12's Avatar
Default Re: (weenie)
what did u use as ur connectors ? I used ring connectors for the valve cover but i cant find any large ones for a 0/1 gauge wire.
Old Nov 9, 2006 | 10:51 AM
kornerk12's Avatar
bump
Old Nov 9, 2006 | 10:59 AM
LilBoi's Avatar
can you guys post pictures of how your grounding looks. I'm planning to do this w/ all the extra amp wire i have.
Spawne32
Jun 28, 2011 10:41 AM
obuhmyuh
13
Feb 11, 2008 05:44 PM
msinsky14
May 23, 2007 06:44 PM
akteamster
Mar 5, 2006 08:51 AM
wannab20hatch
Oct 12, 2002 10:15 AM
