possible fuel problem?
Old Oct 26, 2006 | 10:57 AM
JDMhondalude22's Avatar
Default possible fuel problem?
ok, so i just finished up with my h22 swap... started up, and i let it idle for about a good 20 minutes to warm it up and what not. i had a slight hairline leak in my fuel line from filter to regulator, i fixed it a little so i could run it. (slightly seeps out now, but nothing crazy at all.) car runs fine. i took it out to drive it, made it about 20 -25 minutes away and it started to die out on me and when i gave it gas, it had little reaction at all. now the car wont start. just cranks. has spark, and i can hear the fuel pump. after sitting for 10 minutes it decided to try and start up, but stalled out. i looked at the vacuum from my fuel regulator and its wet with fuel. any ideas?
Old Oct 26, 2006 | 11:08 AM
Default Re: possible fuel problem? (JDMhondalude22)
i might of thought of the problem... slight fuel leak from the hose, causeing poor fuel pressure, causeing fuel pressure regulator to go bad... ???
Old Oct 26, 2006 | 01:21 PM
Perfectionist's Avatar
The leaking FPR is adding too much fuel to the intake causing a flooded condition.
Old Oct 26, 2006 | 02:19 PM
Default Re: possible fuel problem? (Perfectionist)
ok, i changed the fuel pressure regulator and broken fuel line. car started right up, and idled for a minute, and shut off. now wont start. i have spark. no fuel. i can hear the fuel pump run so thats leaving me to believe ruling out the main fuel relay. ???
sgull
Jan 25, 2013 12:43 PM
Newsom91
May 8, 2010 05:26 PM
Slimer89
Jun 2, 2003 12:09 PM
TurboTypeR98
Jan 30, 2002 04:34 AM
