idoling question?
Old Oct 25, 2006 | 12:57 PM
fauxhawkid's Avatar
Default idoling question?
so i just got my alternator installed about less then 3 weeks ago. and 2 weeks after they installed it, my car starts to idol from 1000 to 1500 rpm. it would only do it at times, but now it doesn't constantly everytime i stop. and to top it off, my engine light came on. im broke, so i cant take it in for a diagnostic test.
does anyone know what might the problem be and what can cause a car to idol like that? do i have to replace or buy something?
thanks.
98hondaprelude
Old Oct 25, 2006 | 01:50 PM
nah22accord's Avatar
Default Re: idoling question? (fauxhawkid)
First off I would find out why the cel light is on. I would also check vacume lines, and the IAC valve. Also check your FIC valve under the throttle body by taking your intake tube off the throttle body and while the car running at normal temp plug the bottom hole in the throttle body with your finger. At normal temp it shouldnt be sucking any air.
Old Oct 25, 2006 | 01:55 PM
Chuckles99SH's Avatar
Do a search on how to pull OBD codes, you can short a jumper out and it should flash a series of blips on your CEL, that will tell you the code it is.
Old Oct 25, 2006 | 03:13 PM
fauxhawkid's Avatar
Default Re: idoling question? (Chuckles99SH)
what if it does suck air when i plug the hole?
Old Oct 25, 2006 | 06:03 PM
If it sucks quite a bit even after it is warmed up to normal temp and the fans have kicked on. Then try taking it off. The metal plate that faces the firewall that is held on by two philips screws, take that plate off and inside is a white plastic piece with two indentions across from each other. Get something to turn it and tighten it. Then put it back together and hopefully that fixes it.
Old Oct 28, 2006 | 01:06 PM
fauxhawkid's Avatar
Default Re: idoling question? (nah22accord)
i cant find that valve your talking bout, "Also check your FIC valve under the throttle body by taking your intake tube off the throttle body and while the car running at normal temp plug the bottom hole in the throttle body with your finger"
i tried looking or it, but when i pulled out the valves some sort of liquid came gershing out. i think it was coolant or sum type of fluid. can you tell me more specific where the valve i have to take out and plug the hole with is at?.
and where is that metal plate w/the 2 philips screw located at? i found a plate w/two metal screws but i dont know if thats the one.
jdmeg6honda
18
Jun 15, 2011 07:24 AM
hondateched
Jul 25, 2009 07:49 PM
skylinexr11
Mar 6, 2008 05:02 PM
MadVtak
Dec 15, 2007 01:00 PM
b18c1wes
Dec 7, 2004 02:50 PM
