EGR problem???
Old Oct 31, 2006 | 03:12 PM
Apex1972's Avatar
Default EGR problem???
Ok, since Sleepy won't post this, I will. What would cause an H22 to run better with a CEL than without??? With the EGR system disabled and a CEL on for the EGR, the car runs better than when you put all the vaccum lines and electrical connections for the EGR valve back on and run it. There is a low RPM hesitation it almost sounds like a spark plug wire is off.
Old Oct 31, 2006 | 03:31 PM
sleepyH22's Avatar
when i plug my plug in for the egr and hook the vacuum line for it...the car runs SO bad and will not hardly drive.
when i unplug them botht the car gets a CEL for code 12 "inssuficient egr lift"
but the car runs GREAT with these unplugged but i know the cel isnt cool at all..
SOME ONE HELP PLEASE!!!!!!!
Old Oct 31, 2006 | 04:18 PM
sleepyH22's Avatar
BUMP
HELP NEEDED
Old Oct 31, 2006 | 04:51 PM
Revi's Avatar
Default Re: (sleepyH22)
You are going to get a CEL regardless of what you do to the EGR. If the computer detects malfuntion say hellow to the little CEL.
Why exactly are you doing this anyways?
Old Oct 31, 2006 | 05:54 PM
lude98SH's Avatar
Default Re: (Revi-Ra)
Wut year is it ?
Old Oct 31, 2006 | 08:25 PM
BB6racer's Avatar
sounds like you could have a faulty/clogged egr system. maybe since the ecu thinks the system is malfunctioning when you unplug everything it doesn't even activate the system, but when everything is plugged in the egr system causes problems. but i don't really know, i was just throwing in the idea.
Old Nov 1, 2006 | 02:30 PM
Apex1972's Avatar
Default Re: (BB6racer)
Sounds like that thing may need a good cleaning.
Old Nov 1, 2006 | 04:19 PM
sleepyH22's Avatar
Default Re: (Apex1972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi-Ra &raquo;</TD></TR><TR><TD CLASS="quote">You are going to get a CEL regardless of what you do to the EGR. If the computer detects malfuntion say hellow to the little CEL.
Why exactly are you doing this anyways?</TD></TR></TABLE>
when the plug is plugged in, and vaccum line attached. I HAVE NO CEL! BUT RUNS SOOOO BAD AND WILL NOT MOVE.
my car runs Perfect with no egr hooked up and a cel code 12. I know it sounds crazy but its true.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6racer &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you could have a faulty/clogged egr system. maybe since the ecu thinks the system is malfunctioning when you unplug everything it doesn't even activate the system, but when everything is plugged in the egr system causes problems. but i don't really know, i was just throwing in the idea.</TD></TR></TABLE>
thats what i thought so i cleaned everything and nothing helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">Wut year is it ? </TD></TR></TABLE>
a 94 SI with a h22a1 swapped from a OBD II 96 lude that i wrecked<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex1972 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like that thing may need a good cleaning.</TD></TR></TABLE>
like i said, this whole **** has been cleaned and cleaned and recleaned!!
I NEED HELP
Old Nov 1, 2006 | 06:14 PM
Cory man's Avatar
When the EGR vac lines are removed you are essentially bypassing it. If the car runs better when EGR is disconnected the ports are clogged. If you have cleaned them then it wasnt done properly. 1 port being clogged can cause a problem. Did you use a small drill bit or something equivalent to break through ALL of the carbon in each of the EGR ports?
Old Nov 1, 2006 | 06:31 PM
AllmansDB8*'s Avatar
Default Re: (Cory man)
Your EGR valve could also be sticking as well. Swap with a known good part if you can.
Old Nov 2, 2006 | 01:04 PM
sleepyH22's Avatar
Default Re: (AllmansDB8*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cory man &raquo;</TD></TR><TR><TD CLASS="quote">When the EGR vac lines are removed you are essentially bypassing it. If the car runs better when EGR is disconnected the ports are clogged. If you have cleaned them then it wasnt done properly. 1 port being clogged can cause a problem. Did you use a small drill bit or something equivalent to break through ALL of the carbon in each of the EGR ports? </TD></TR></TABLE>
honestly all i did was removed the egr and cleaned only right there...
this engine ran perfect in my 96 lude and it went DIRECTLY from that car to my 94 si...i just dont see how they would have clogged in the middle of me doing the swap...and this swap was done Professionally by me and my dad at our shop...so i just really need an EXACT DETAILED HOW TO on how to do this procedure you speak of.
Old Nov 3, 2006 | 08:18 AM
sleepyH22's Avatar
bump
help please...anyone else experience this..?!
btw this is a OBD II h22a1 (96) in a 94 si...
it has the obd I dist and stuff but i still am runnin the 295cc obd II injectors when i really need the 345cc obd I h22 injectors but i really dont think the injectors have anything to do with this.
Shollman
Apr 22, 2017 03:17 PM
sumoneEK
Nov 22, 2010 11:29 AM
Powered By Garrett
Feb 16, 2007 12:20 PM
CompanyFlow
Acura TL, RL & ZDX
Oct 26, 2006 08:24 AM
