help with engine problem (searched)
Old Jul 10, 2007 | 04:16 PM
93ludesitec's Avatar
Default help with engine problem (searched)
alright... i havent been on in awhile, but i really need a little help.. my setup is, 93 prelude, h22a swap, crower stage 1 cams, intake, dc header, and skunk 2 exhaust... low end power is alright, not what it used to be, but when i hit vtec, it gets really, really loud, like valve float, and has absolutly no power... i tried a valve adjustment, and it didnt help... ignition timing is fine... and i have no codes... please help...thank you
Old Jul 10, 2007 | 04:20 PM
us31wking's Avatar
Default Re: help with engine problem (93ludesitec)
really just sounds like a tuning problem. my biggest issue when i put all of my bolt on mods on my car is gonna be "how it all works together"
scary thing is, im getting a lot of the same parts
im thinking its ecu problems and such
i take it the car worked fine with the old engine? yes, no?
Old Jul 10, 2007 | 06:41 PM
Default Re: help with engine problem (us31wking)
o yea, but what i forgot to tell you guys was it has ran perfect for the past year... up untill recently it has been beautiful... again, thanks for the help!
Old Jul 10, 2007 | 08:23 PM
us31wking's Avatar
did you add anything and then it started
or did it happen instantly or gradually?
Old Jul 11, 2007 | 06:37 AM
shaylude's Avatar
i'd like to help but i'm having problems with my h22a even hitting vtec...
nice to see another prelude in indiana
Old Jul 11, 2007 | 06:41 AM
carnot's Avatar
did you check all your fluids and such? Is there any type of smoke coming out of the exhaust? Do a leakdown and compression check.
Old Jul 11, 2007 | 06:48 AM
shaylude's Avatar
Default Re: help with engine problem (carnot)
(Srry to kinda jack the thread)
but, no..and for some reason now when i start it up after it has been sitting it idles at like 700-1000 and has absolutely no power, then idles at around 1900.
checked my oil last night and i'm starting to lose oil..
getting scared, its parked.
Old Jul 11, 2007 | 07:05 AM
carnot's Avatar
Default Re: help with engine problem (shaylude)
the oil has to be going somewhere...if you aren't leaking it out it must be burning up. In your profile it says h22/h23...does that mean you are running a h23 block and h22 head or do you just have a jdm h22a? high idle could be vacuum leak, FITV, IACV...etc lots of info if you search about high idle. As far as no power...like you throttle it and it doesn't go anywhere?
Old Jul 11, 2007 | 07:39 AM
hondapreludehelp's Avatar
high idle
Old Jul 11, 2007 | 07:40 AM
shaylude's Avatar
no h22a motor/h23a1 tranny. its not together yet but i have the h22a w/ h22 tranny in another lude of mine that is running. but im swapping the motor over since i blew my h23a1 and the h22a tranny is all messed up...
if i do go down the road it will bogged down and then pick up and fly down the road...its weird
Kalani Spillner
Apr 1, 2016 11:39 PM
lcjarrett
Dec 2, 2005 07:24 AM
mayhemdestroy
Jul 10, 2005 08:22 AM
Johnny.
Jan 6, 2003 07:57 PM
