Clutch Bleeding
Old Jul 17, 2007 | 12:18 PM
jdmh22luda's Avatar
Default Clutch Bleeding
Hey I am bleeding my clutch...tell me if im doing it wrong
1. Unscrew nipple so fluid comes out (hose at the end of it going from the nipple to a full can of fluid so no bubles get in)
2. Have a friend pump the clutch pedal while continuing to keep the resevoir full
3. Do this until all bubbles are out, friend must keep clutch pressed in....and tighten everything up
RIGHT??
Old Jul 17, 2007 | 12:27 PM
Eddiebx's Avatar
yep, but just keep in mind if there is air in ur lines, it might take ALOT of pumping, so dont be afraid if nothign cones out for a few mins, it will eventually start to come out
Old Jul 18, 2007 | 05:18 AM
jdmh22luda's Avatar
Default Re: (Eddiebx)
There was air in the line before and I wasn't able to shift at certain rpm's, so an attempt last night to bleed the line over and over went bad somewhere along the line and I couldn't even drive the car to work today because the clutch had no pressure.
I followed the steps I listed above and have done this simple task before and cannot figure out what I am doing wrong and becoming so frustrated! Help me PLEASE!! I cannot figure it out!
Old Jul 18, 2007 | 06:11 AM
94vtecmn's Avatar
Default Re: (jdmh22luda)
Pump the pedal slowly. If you move it too quickly, you won't get the air out.
Old Jul 18, 2007 | 06:14 AM
jdmh22luda's Avatar
Default Re: (94vtecmn)
I guess I don't understand what the difference would be
Old Jul 18, 2007 | 07:06 AM
carnot's Avatar
I bled my clutch using one of those vacuum pumps. I don't know if that is the proper way of doing it but it seemed to work for me. The steps are pretty easy. Loosen bleeder valve, attach vacuum pump, keep reservoir full, operate the pump until a solid stream of fluid is coming out of the bleeder valve, close bleeder valve.
Old Jul 18, 2007 | 07:36 AM
jdmh22luda's Avatar
Default Re: (carnot)
I think I bled my clutch correctly but feel that air is getting in another way, no obvious leaks....where have others had leaks at....plus the slave cylinder is almost brand new
Old Jul 18, 2007 | 08:29 AM
Mr.Luder's Avatar
where can i get one of those pumps?
Old Jul 18, 2007 | 11:43 AM
93sivtec's Avatar
Default Re: (Mr.Luder)
They have them at the autozone and other part stores just like that....checker,pepboys etc.
Old Jul 19, 2007 | 03:52 AM
zsudz922's Avatar
Default Re: (93sivtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmh22luda &raquo;</TD></TR><TR><TD CLASS="quote">I think I bled my clutch correctly but feel that air is getting in another way, no obvious leaks....where have others had leaks at....plus the slave cylinder is almost brand new
did you also replace th master cylinder?they say you should replace them both at the same time when one or the other dies.i guess because when one dies the other one is close to being dead as well.
Old Jul 19, 2007 | 08:43 AM
chitownrida's Avatar
u got the method down, mine wouldnt bleed out because air was getting sucked back in thru the threads of the bleed valve.. i threw some teflon tape on the sob and it fixed it. good luck
Old Jul 19, 2007 | 08:51 AM
kornerk12's Avatar
Default Re: (chitownrida)
so u pump the clutch pedal and dont close the bleeder between pumps ?
So this is completely different than brakes i guess ?
Old Jul 19, 2007 | 11:52 AM
jdmh22luda's Avatar
Yea i just had to make sure the tube was past some of the threads on the bleeder and it worked fine, no more air!! Problem solved...
Old Jul 26, 2007 | 01:02 AM
Mr.Luder's Avatar
</TD></TR></TABLE>check inside the car behind the clutch peddle. check where the push rod and clutch master cylinder meets. thats where my leak was. took me forever to find it.
ja20_eg
Sep 17, 2012 03:54 PM
diviznrider
Feb 4, 2011 11:01 AM
Bserieskiller
Feb 17, 2006 05:52 PM
Whig-it
Jun 21, 2004 06:21 PM
d16y8turbo
Apr 17, 2004 10:40 PM
