Ecu Cel code
Old Jul 17, 2007 | 10:04 AM
H23forlife's Avatar
Default Ecu Cel code
I have a 95 prelude which i just swapped to a h22a and i am getting a cel but i can not pull it from the ecu. For some reason it isnt saying the code. Well my question is is there any reason it wouldnt save the code.
Old Jul 17, 2007 | 12:49 PM
Finest's Avatar
Default Re: Ecu Cel code (H23forlife)
Did you jump the service connector?
BTW, I guess you gotta change your name now, huh?
Old Jul 17, 2007 | 01:49 PM
prelude_93vtec's Avatar
Default Re: Ecu Cel code (Finest)
^ lol. search it. all u gota do is jump the service connector as he was saying.
Old Jul 17, 2007 | 11:40 PM
H23forlife's Avatar
Default Re: Ecu Cel code (prelude_93vtec)
yes i need to change my name now and plus i have jumped the service connector and there is not any codes but when i turn the car on it throws cel.
Old Jul 18, 2007 | 12:17 AM
CHK4TIX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23forlife &raquo;</TD></TR><TR><TD CLASS="quote">yes i need to change my name now and plus i have jumped the service connector and there is not any codes but when i turn the car on it throws cel.</TD></TR></TABLE>
Do you mean, it shows a cel when the car is on and the jumper is jumped? if so, that means there are no codes and it is suppose to do that
Old Jul 18, 2007 | 09:22 AM
H23forlife's Avatar
no whenever my car is started without the jumper. the cel light comes up, but when i try to jump the connector it does not throw any numbers.
Old Jul 18, 2007 | 12:01 PM
JasonST's Avatar
I've been told that when that happens it usually means ur ecu is bad. But i'm not 100% positive so search and ask around.
Old Jul 18, 2007 | 12:10 PM
xxmastermindxx's Avatar
ok well just for clarification, lets make sure you are doing it the right way...
-car off, key out of ignition.
-jump the service connector (blue, two pin, behind radio)
-turn key to on position (don't start the car)
-any stored CELs will show
Old Jul 18, 2007 | 10:56 PM
H23forlife's Avatar
Default Re: Ecu Cel code (xxmastermindxx)
Yes i know how to pull up cel codes
Old Aug 24, 2007 | 11:24 AM
young geezer's Avatar
i have lots of engine light code but dont know wat those are. can some one give me the ecu codes for the 93 perlude. searched but couldnt find it. thanks.
Old Aug 24, 2007 | 11:27 AM
mgags7's Avatar
when you jump it does the light just stay solid or does it go out?
Old Aug 24, 2007 | 11:33 AM
Default Re: (mgags7)
no it throws code 6, 10, 21, 42,and i thikn thats it. just trying to find wat those codes are. i couldnt find the link where they have the all the code.
Old Aug 24, 2007 | 11:37 AM
mgags7's Avatar
http://www.c-speedracing.com/faq/05.php
6- ect
10- iat
21- vtec sol.
42- this code doesnt' exist as far as i know, read again.
I think you simply have some connectors mixed up.
Hetterley
Engine Management and Tuning
Apr 19, 2016 06:54 PM
pedroa06
Feb 9, 2010 02:42 PM
1sikhatch
Jan 31, 2010 09:06 AM
esca
Oct 14, 2004 06:34 PM
