vtec qustion
Old Jul 10, 2007 | 01:42 PM
chicken18's Avatar
Default vtec qustion
ok i advanced my timing with timing light. Everything works good and performing good , but one problem. I noticed my 1st gear does not hit vtec strong. Second gear it hits better i think but not first. I just seems to make lots no noise and seems like it is working but no pull. Anyone got any reason why this might be happing.?
Old Jul 10, 2007 | 01:44 PM
mgags7's Avatar
set your timing back to stock.
Old Jul 10, 2007 | 01:51 PM
98vtec's Avatar
moderator emeritus
Default Re: (mgags7)
change your oil
clean vtec solenoid
your prolly worrying about this because you dont feel the kick as much. This is a good thing. It means you likely gained some midrange.
Old Jul 10, 2007 | 02:16 PM
blake92lude's Avatar
Yea, you most likely are pulling harder from low to high so you dont feel it kick as much because it's faster all around....But yea change your oil (Of course)...And I would suggest using premium gas (Reduces sludge and makes your engine run longer)
Old Jul 10, 2007 | 02:26 PM
mattsnooz's Avatar
Default Re: vtec qustion (chicken18)
I would agree with mgags. Timing!
poll anybody? jk
Does it idle any different with your timing adjustment? ie. sputter or ping?
Old Jul 10, 2007 | 02:30 PM
chicken18's Avatar
Default Re: vtec qustion (mattsnooz)
no idle just little higher nothing that makes car run bad just first gear does not hit as hard. I did gain low end speed just when hit the vtec it not engaging.
Old Jul 10, 2007 | 05:29 PM
m.online's Avatar
Butt dynos are unreliable.
They're probably right, you gained some low-midrange and don't feel the kick as much due to that.
hk_gsrguy
Sep 15, 2012 08:40 PM
Shag Wagon
Aug 10, 2011 04:40 PM
bushfreakz
Jul 17, 2003 03:21 PM
GreenGSR
Jul 28, 2002 07:12 PM
