Another timing question.
Old Jul 9, 2007 | 06:59 PM
racer69's Avatar
Default Another timing question.
If you jump your ECU to set your timing on an h23, does that also mean that your timing can't advance or retard while the jumper is attached? So if you have a bad sensor, you could still check your timing....or is that not true?
Old Jul 10, 2007 | 05:03 AM
racer69's Avatar
Default Re: Another timing question. (racer69)
Bump.
Old Jul 10, 2007 | 07:26 AM
Hawkze_2.3's Avatar
Um...if you try to adjust the ignition timing without jumping the ECU, the computer will try adjust the timing itself against your adjustments. If you jump the ECU, then you can freely adjust the timing yourself.
What sensor do you mean?
dean2
Dec 27, 2006 11:21 AM
FyReo3
Aug 27, 2004 04:12 PM
integrx
May 12, 2004 02:48 PM
integrx
Jan 15, 2004 11:37 PM
