NO IDEA!!!!!
Old Sep 3, 2007 | 06:29 PM
preludepimpin8668's Avatar
Default NO IDEA!!!!!
hey i got an 86 honda prelude 2.0 fuel injected and it wont start, the fuel pump went and then i changed it and it wont start all it does is turn over and the first time i turn it over it will start and rev up to about 2000rpm and then quit then it will just turn over i heard it cud be a bad battery feed to the injectors but im not sure got any info for me? --
Old Sep 3, 2007 | 06:32 PM
reptar_head's Avatar
Default Re: NO IDEA!!!!! (preludepimpin8668)
Is the fuel pump getting power? If so, next thing to check might be fuel pressure. That's a start at least.
Old Sep 3, 2007 | 07:37 PM
Default Re: NO IDEA!!!!! (reptar_head)
yeah the fuel pump is gettin power and i checked im getting gas all the way up to the injectors.....im just not sure what the hell to do anymore. i checked to see if a sensor was blinking but i could not see anything so im not sure.
Old Sep 4, 2007 | 09:47 AM
guessman's Avatar
how much pressure are you showing going into the fuel rail?
Old Sep 4, 2007 | 11:14 AM
Default Re: (guessman)
how do i check how much fuel pressure is going into the fuel rail
Old Sep 4, 2007 | 11:22 AM
guessman's Avatar
hook up a pressure guage to it. I've seen some write ups about that on here and Preludepower.com has a few to.
Old Sep 4, 2007 | 11:36 AM
NATE92SI's Avatar
DID YOU CHECK YOUR INJECTORS? JUST MAKE SURE THEY ARE TAPPING.
Old Sep 4, 2007 | 01:38 PM
Default Re: (NATE92SI)
im not sure what u mean by tapping ??? and if i take off the intake and squirt gas into there it will run but soon as i stop squirtin gas in there it dies, im thinking its a bad battery feed to the injectors so if u got any info on the wiring you shud let me know.....thanx
autotegra
Honda Civic (2001 - 2005)
Jan 28, 2015 07:38 PM
caspersrevenge1
Sep 6, 2013 05:02 PM
gonmaro
Feb 17, 2009 07:09 PM
TexasluvsHondas
Nov 21, 2006 07:37 PM
sol2nr
11
Jun 23, 2004 06:36 PM
