Motor Sputtering when driving
Old Aug 31, 2007 | 09:50 PM
allentownrep's Avatar
Default Motor Sputtering when driving
Just got a question for u guys...i tried searching but i wasnt entirely sure how to look up...I recently did a JDM H22A w/LSD swap and i seem to be have a couple of issues. It seems to be that when im about to ride out... the car starts to sputter unti l reach about 2500-3000rpm...But thats when im driving normal but when i wanna try it out (as in Punching it) it starts to sputterall the way up to when vtec kicks in then it goes normal...I was thinking that i probably need to get it chipped then tuned..or is it not throwing suffecient amount of fuel...or is it misfiring ...any suggestions would be greatly appreciated
Old Aug 31, 2007 | 10:02 PM
Hawkze_2.3's Avatar
Default Re: Motor Sputtering when driving (allentownrep)
First thing I would do is double check the ignition and cam timing....I wouldn't get it 'chipped' just yet...
Old Aug 31, 2007 | 10:13 PM
Default Re: Motor Sputtering when driving (Hawkze_2.3)
so ur saying that the belt coudlve jumped a tooth? or just some adjusting...would it be a good idea to buy an MSD cap? since i already have a blaster 2 (converted to external ignition coil)
Old Aug 31, 2007 | 10:25 PM
Hawkze_2.3's Avatar
Yeah, probably not the most likely thing, but stuttering is a consequence of having the timing off a tooth. Also the tensioner could have slipped or something...you never know.
I would skip the MSD cap and coil...won't do anything except raise your chances of having problems.
Old Aug 31, 2007 | 10:28 PM
So basically...Just Keep everything honda...By the way im not sure or not but my friend who knows a whole shitload about H22's Told me that my motor came with Aftermarket cams...he said either Type-s or ATR
Modified by allentownrep at 11:40 PM 8/31/2007
Old Aug 31, 2007 | 10:40 PM
Hawkze_2.3's Avatar
Default Re: (allentownrep)
Yep, among the things Honda has done very well are the ignition systems on their cars.
Old Aug 31, 2007 | 10:56 PM
Default Re: (Hawkze_2.3)
Nice...Thanks Hawkze...i appreciate ur help...but as always...im up for other suggestions
Old Sep 1, 2007 | 05:48 AM
mgags7's Avatar
Coming from someone who has had their share of ignition problems, stick with honda stuff.
Those cams shouldn't cause you to sputter down there like that, I would check ignition timing first, then take a look at the spark plugs. If neither of those are it, come back and post up again.
Old Sep 1, 2007 | 06:03 AM
PreludePhill's Avatar
Default Re: (mgags7)
Maybe try your coil or ignitor inside yout Dist.
Old Sep 1, 2007 | 06:36 AM
mgags7's Avatar
Default Re: (PreludePhill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludePhill &raquo;</TD></TR><TR><TD CLASS="quote">Maybe try your coil or ignitor inside yout Dist.</TD></TR></TABLE>
He has an msd coil. I would def check the ICM though.
SoFresh1189
Apr 4, 2013 10:40 AM
lrayford
Nov 24, 2008 12:45 PM
prelude72569858
Jan 9, 2006 08:52 PM
96b18c
Dec 28, 2004 11:31 AM
