new idle problem....
Old Sep 3, 2007 | 02:04 PM
IAluder95's Avatar
Default new idle problem....
it stop have a bad idle, and now goes from 1000-2100 rpm 5 times then just kills itself.
once again, no EGR, no Cold idle start. most Vaccum lines not installed that connect to the intake manifold.
any ideas?
Old Sep 3, 2007 | 02:30 PM
IAluder95's Avatar
is the map sensor under the IM manifold?
Old Sep 3, 2007 | 05:31 PM
jdmlude5
Guest
Posts: n/a
Default Re: (IAluder95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAluder95 &raquo;</TD></TR><TR><TD CLASS="quote">is the map sensor under the IM manifold?</TD></TR></TABLE>
no. if your car is obd2 its on the top of the throttlebody. if its obd1 its on the firewall rite behind the throttlebody. it seems like u have a vacume leek. use carb cleaner and spray around the im gaskets when the idle changes u found a leak.
Old Sep 3, 2007 | 06:04 PM
98vtec's Avatar
moderator emeritus
are you running any kinda of engine management?
Old Sep 3, 2007 | 09:40 PM
IAluder95's Avatar
no engine management.
i think i got it figured it out tho.
Old Sep 4, 2007 | 07:39 AM
h22a1_julien's Avatar
Default Re: (jdmlude5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude5 &raquo;</TD></TR><TR><TD CLASS="quote">
no. if your car is obd2 its on the top of the throttlebody. if its obd1 its on the firewall rite behind the throttlebody. it seems like u have a vacume leek. use carb cleaner and spray around the im gaskets when the idle changes u found a leak. </TD></TR></TABLE>
my motors obd1 and my map sensors on the top...
Old Sep 4, 2007 | 02:06 PM
IAluder95's Avatar
my map sensor is bad, so its idle surging.
Old Sep 4, 2007 | 03:12 PM
mattsnooz's Avatar
why use carb cleaner to test for air leaks? can't you just use good ole water and not have to worry about carb cleaner eating out gaskets and other non-corrosion-resistant materials??
or is water worse?
quick_ls
Jun 17, 2006 11:06 AM
TURBL0W
Feb 12, 2006 06:12 PM
acc97lxAndy
Apr 13, 2004 10:30 PM
Race Egr
Apr 5, 2004 10:32 PM
madiaz
Sep 10, 2003 01:13 PM
