Alignment or what
Old Sep 4, 2007 | 06:34 PM
prelude_93vtec's Avatar
Default Alignment or what
hey the lude has been pulling to the left for a while now. its real bad when i brake the car jus pulls to the left. what can be the problem with this? i went to NTB and they said they couldnt do anything about it and didnt know what was wrong with ti but i think they were BS because i had the 1 year alignment program. can anyone tell me why its pulling to the left so much?
Old Sep 4, 2007 | 07:17 PM
prelude_h22vtec's Avatar
it only pulls to the left when braking? did NTB check the alignment? if your toe or caster is out it will pull.
Old Sep 4, 2007 | 07:24 PM
Default Re: (prelude_h22vtec)
ya the tires do look a little bit angled out. i might have to check that out. what are the proper numbers for everything?
Old Sep 4, 2007 | 07:48 PM
InvaderTrax's Avatar
If it's a program alignment, they should have done is simply because you said to, and given you a printout. If it only does it when braking, you need to check your brakes. Either you have a sticking caliper or slider, or something's greased up your pads . If it's while driving, worse when braking, could be a bad tire
Old Sep 5, 2007 | 01:44 PM
Default Re: (InvaderTrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">If it's while driving, worse when braking, could be a bad tire</TD></TR></TABLE>
exactly. can it be cause of low air pressure?
Old Sep 5, 2007 | 02:32 PM
Eddiebx's Avatar
i'd check out ur strut rod bushings, mabye the caster is moving around too much during braking, due to bad bushings.
Old Sep 5, 2007 | 03:48 PM
Default Re: (Eddiebx)
so what do you guys recommend?
Old Sep 5, 2007 | 05:22 PM
TheLudeMan's Avatar
Default Re: Alignment or what (prelude_93vtec)
mine goes to the right and the steering wheel faces the right, what is my problem?
Old Sep 5, 2007 | 07:29 PM
Default Re: Alignment or what (TheLudeMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheLudeMan &raquo;</TD></TR><TR><TD CLASS="quote">mine goes to the right and the steering wheel faces the right, what is my problem?</TD></TR></TABLE>
your toe needs to be adjusted
preludeNApower
Suspension & Brakes
Oct 19, 2011 05:13 AM
civic_tuned
Suspension & Brakes
22
Jul 9, 2006 08:36 AM
streetlegal gocart
Sep 25, 2004 09:40 AM
92_red_teg
Jul 13, 2004 10:36 AM
TegRun
Mar 26, 2004 11:26 AM
