Installing struts ??
Old Aug 28, 2007 | 09:12 PM
kornerk12's Avatar
Default Installing struts ??
I have done this before however i took these out about a week ago (car is on jackstands) and tonight i went to put them back and they didnt want to line up. Does anyone have some pictures that i could look at to verify i am doing this right or wrong ?
Old Aug 29, 2007 | 08:48 PM
kornerk12's Avatar
Default Re: Installing struts ?? (kornerk12)
bump
Old Aug 29, 2007 | 08:51 PM
snobordboy's Avatar
Moderator
Umm, what part is confusing, we need more info! I just did Konis on my 4th gen this week so I may be able to help!
Old Aug 30, 2007 | 05:06 AM
kornerk12's Avatar
Default Re: Installing struts ?? (snobordboi)
im installing my struts and i cant get it to line up with the holes arou d the srtut tower. Is there an order i have to install them or a trick to getting them in ?
Old Aug 30, 2007 | 09:00 AM
integra15's Avatar
Did you align the shock fork tab to the upper mounting studs? If you did not, just leave the top nut loose when installing it and you should be able to rotate the shock by hand to get the tab to line up. Then tighten everything afterwords. Same concept for the rears.
Modified by integra15 at 8:21 PM 8/31/2007
Blazin Civic
Mar 25, 2005 10:44 PM
vulgar_si
12
Feb 29, 2004 02:17 PM
