antenna problem
Old Sep 1, 2007 | 10:09 PM
paniaguae640's Avatar
Default antenna problem
my antenna makes a bad noise when it goes up and or down, could it be a bad motor?
Old Sep 1, 2007 | 11:19 PM
InvaderTrax's Avatar
A "bad noise" could be a number of problems...
Old Sep 2, 2007 | 12:03 AM
snowblind7x's Avatar
Default Re: antenna problem (paniaguae640)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paniaguae640 &raquo;</TD></TR><TR><TD CLASS="quote">my antenna makes a bad noise when it goes up and or down, could it be a bad motor?</TD></TR></TABLE>
if it still goes up or down its probly not the motor. You can either get a new antenna (off ebay for like $20 bucks) or just wd-40 your current one
Old Sep 2, 2007 | 01:00 AM
BlackCatt's Avatar
A bit of lubrication did the trick on mine. Never sticks anymore.
Old Sep 2, 2007 | 09:50 AM
does it matter what type of thing you use to lubricate it?
Old Sep 4, 2007 | 04:12 AM
BlackCatt's Avatar
WD-40 or RP-7. Make the aerial go up and down a few times then wipe up any excess. If no luck get one 2nd hand.
Old Sep 4, 2007 | 07:46 AM
igorski_89's Avatar
maybe bad motor for the power antenna?
Old Sep 4, 2007 | 02:52 PM
prelude-all-the-way's Avatar
Default Re: (igorski_89)
here was my solution buy a s2000 one that is rubber about 7 inches tall no motor direct fit on oem $25 off ebay
Old Sep 5, 2007 | 10:16 AM
slysi92's Avatar
Default Re: (prelude-all-the-way)
mine made bad growl sound, gear was striped, my sullution, was to shave it and use invisable antena
HondaVerno
Mar 19, 2008 02:57 PM
teg_dc2
Dec 10, 2007 11:39 AM
mxteam
Aug 10, 2007 09:20 AM
shivsharma6
Apr 16, 2004 05:39 PM
Type RS
Jun 15, 2003 01:48 PM
