engine getting hot real quick?
Old Sep 6, 2007 | 04:20 PM
mikeaitken's Avatar
Default engine getting hot real quick?
Lately my car heats up real quickly. Ill drive it to my buddies like 15 min away. if that. and my **** is hot as expletive. i can feel it near my floor board too.comin thru. I do need to change my clutch cause its burnt the expletive out. Could that be the problem, just like some friction burning heat off????
Old Sep 7, 2007 | 08:44 AM
prelude1897's Avatar
Default Re: engine getting hot real quick? (mikeaitken)
what's the temp gauge say on your gauges? Do you have your vents closed? If your vents are open, then hot air is giong to blow into your car
Old Sep 7, 2007 | 08:52 AM
mgags7's Avatar
a clogged catalytic converter would produce a lot of heat, does the car feel doggish at all?
Old Sep 7, 2007 | 09:57 AM
NATE92SI's Avatar
Default Re: (mgags7)
It could be the thermostat stuck shut or a clogged radiator. Are your fans coming on?
Old Sep 7, 2007 | 01:01 PM
mikeaitken's Avatar
Default Re: (NATE92SI)
my temp gauge is directly in middle. like im not overheating. i have fresh anti freeze. fresh oil change too. fans do work i know cause they came on while ago when i didnt have too much antifreeze, haha. The car does kinda dogg around a lil. i thought it was my o2 sensor, cause that did help a lil bit.
Old Sep 7, 2007 | 01:19 PM
Finest's Avatar
Default Re: (mikeaitken)
Does it smell like rotten eggs?
Old Sep 7, 2007 | 03:11 PM
allentownrep's Avatar
Default Re: (Finest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">Does it smell like rotten eggs?
yeah wat does it mean if it smells like rotten eggs..because sometimes when punch it afterwards it smells like rotten eggs
Old Sep 7, 2007 | 10:59 PM
mikeaitken's Avatar
Default Re: (allentownrep)
nah. my car smells real rich sometimes and like burnt oil. i think its gnna be bad too. knowing my luck
Old Sep 8, 2007 | 06:49 AM
preludefien
Guest
Posts: n/a
smells like rotten eggs i think your cat is done for
Old Sep 8, 2007 | 06:50 AM
preludefien
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeaitken &raquo;</TD></TR><TR><TD CLASS="quote">nah. my car smells real rich sometimes and like burnt oil. i think its gnna be bad too. knowing my luck</TD></TR></TABLE>
your not throwing any cels are you
Old Sep 8, 2007 | 07:10 AM
mikeaitken's Avatar
Default Re: (preludefien)
nope. no cels or funky smell going on.
Old Sep 8, 2007 | 12:28 PM
preludefien
Guest
Posts: n/a
well thats odd. your not loosing any coolant are you.
Old Sep 8, 2007 | 01:19 PM
mikeaitken's Avatar
nah. yeah idk what to do. its weird. i mean it gets ****** hott. my valve cover is burnin after like 15 min of drivin. not even that. even after leaving my car and starting it latr.
Old Sep 8, 2007 | 02:20 PM
shaylude's Avatar
same here, ^^ when i open the hood i have to stand back or my eye brows will get burnt off lol
Old Sep 8, 2007 | 06:21 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allentownrep &raquo;</TD></TR><TR><TD CLASS="quote">
yeah wat does it mean if it smells like rotten eggs..because sometimes when punch it afterwards it smells like rotten eggs</TD></TR></TABLE>
bad cat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeaitken &raquo;</TD></TR><TR><TD CLASS="quote">nope. no cels or funky smell going on.</TD></TR></TABLE>
do you have a half size radiator or anything? do your fans work? running lean will make your car run hot.
wseg
Nov 7, 2015 08:27 AM
freefall365
Oct 24, 2010 11:30 AM
electric-boost
Dec 11, 2006 08:37 PM
B00STED Si
Jun 16, 2005 08:26 AM
canadiancoch
19
Jan 13, 2004 11:41 PM
