Type-S motor issues
Old Aug 29, 2007 | 06:33 PM
96SinisteR_Lude's Avatar
Default Type-S motor issues
Ive been asking everyone but i need to get my info before i start to let this guy get me a type-s motor not sh......just want to know if anyone know if a h22a type-S fit into a 96 si prelude 2.3....and what conversions would i need to know before installing
Old Aug 30, 2007 | 04:34 AM
Speedra500's Avatar
Default Re: Type-S motor issues (96SinisteR_Lude)
yes it fits, you need the ECU for the type-s or some type of EMS(at least a P13) and IIRC you'll have to wire in vtec, and there is a how-to thread on that
Old Aug 30, 2007 | 07:18 AM
Revi's Avatar
Default Re: Type-S motor issues (Speedra500)
Are you getting a Type-S from a 5th gen JDM prelude? Or a S H22a from the 4th gens?
Old Aug 30, 2007 | 08:45 AM
dtec's Avatar
Default Re: Type-S motor issues (Revi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi &raquo;</TD></TR><TR><TD CLASS="quote">Are you getting a Type-S from a 5th gen JDM prelude? Or a S H22a from the 4th gens?</TD></TR></TABLE>
Type S motors only came from 5th gens. H22A Type S is OBDII and his car is OBDII so it shouldn't be a problem.
Old Aug 30, 2007 | 09:31 AM
Revi's Avatar
Default Re: Type-S motor issues (dtec)
Well he said its a Type-S motor non-sh, well all Type-S motors are pretty much SH motors and bring ATTS so he will have a problem. Its kinda useless to get the Type-S if your not gonna utilize ATTS when you can just get teh Euro-R.
Old Aug 30, 2007 | 03:58 PM
so it point less to get the type s cuz i wont have the atts box. ok but i dont care for that cuz i wouldnt be able to up-grade much cuz i want to boost it with turbo plus im using my h23 tranny better wit the boost.....but if your saying the type-s is basicly the sh motor but wit out the atts then that sucks.
H22A1 2.2L USDM DOHC VTEC 92-96 Prelude VTEC 190hp
H22A4 2.2L DOHC VTEC 97-01 Prelude VTEC/SH 97-98: 195hp 99-01: 200hp
H22A 2.2L JDM DOHC VTEC 92+ Prelude Type-S, 97+ Prelude SiR S Spec 220ps
H23A1 2.3L USDM DOHC non-VTEC Prelude Si 160hp
Modified by 96SinisteR_Lude at 3:21 AM 8/31/2007
Old Aug 30, 2007 | 04:05 PM
dtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96SinisteR_Lude &raquo;</TD></TR><TR><TD CLASS="quote">so it point less to get the type s cuz i wont have the atts box. ok but i dont care for that cuz i would be able to up-grade much cuz i want to boost it with turbo plus im using my h23 tranny better wit the boost.....but if your saying the type-s is basicly the sh motor but wit out the atts then that sucks.
H23A1 2.3L USDM DOHC non-VTEC Prelude Si 160hp </TD></TR></TABLE>
The USDM H22A4 was rated at 195 and 200hp, but I thought those numbers were debunked and they were actually the same as the H22A1 (190hp)? If that's true, then:
H22A1 = 190hp
H22A4 = 190hp
H23A1 = 160hp
H22A = 200hp
H22A Type S/Euro R = 220hp
Old Aug 30, 2007 | 08:14 PM
ok if the type-s ( red top ) is a sh but with out the atts box on the block, would it have a 3 hole bracket for the intermediate shaft ( half shaft ) or the 4 hole ( 2 holes on each side ) like the sh model does to hold the atts box in place????????????????????????????????????????? and that list of h22's i found looking thru different web sites cuz i need my car back on the road
Old Aug 31, 2007 | 03:04 AM
Revi's Avatar
If its a Type-S engine and it comes without the ATTS unit it will still be an SH block. Which means you are gonna need an adapter plate for the intermediate shaft and you will also need a base tranny. You cant use a base intermediate shaft on an SH block with out the adapter plate. Like i said, its more work than you really need to do if you just went Euro-R or regular JDM H22.
Old Aug 31, 2007 | 05:29 AM
Altilude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96SinisteR_Lude &raquo;</TD></TR><TR><TD CLASS="quote">so it point less to get the type s cuz i wont have the atts box. ok but i dont care for that cuz i wouldnt be able to up-grade much cuz i want to boost it with turbo plus....[/i]</TD></TR></TABLE>
why would you get the type s engine if you want to boost? the type s has 11:1 compression ratio, a lower compression would be better for your application, like a usdm h22a1 or 4 would be better suited/cheaper. With the extra coin you could do a better build for turbo.
Old Aug 31, 2007 | 08:02 AM
dtec's Avatar
Default Re: Type-S motor issues (Altilude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Altilude &raquo;</TD></TR><TR><TD CLASS="quote">
why would you get the type s engine if you want to boost? the type s has 11:1 compression ratio, a lower compression would be better for your application, like a usdm h22a1 or 4 would be better suited/cheaper. With the extra coin you could do a better build for turbo.</TD></TR></TABLE>
Yeah, it's pretty much pointless to get the Type S engine if you're going to go boost. The whole reason why the Type S engine makes 20 more ponies is the upped compression. If you're boosting, you're most likely going to be lowering compression to 9:1 or 9.5:1, which defeats the purpose of the Type S engine.
Old Aug 31, 2007 | 09:39 AM
ok thank my bad tho im very new to preludes' so i didnt kno that the 11:1 ratio is a bad thing but thank you alot wit the information......but when i get it do i need to change the power steering pump pulley to fit it into a 96 si and besides the intermediate shaft, are there any other conversion you would kno that i would prob need to do
ludefreak98
Sep 8, 2008 06:20 AM
MadCityLude
Sep 22, 2006 09:45 AM
H22ACiViC
Jan 17, 2002 09:37 AM
tim.simpson
Dec 25, 2001 10:36 AM
