Oxygen Sensor Replacement
Old Aug 31, 2007 | 11:59 AM
Mike1995HondaPrelude's Avatar
Default Oxygen Sensor Replacement
My OBD1 on my 95 PreludeVTEC says it needs a new oxygen sensor. Is it an easy repair? I have very little experience working with cars. My mechanic adviced I only use honda parts. How about Denso or Bosch sensors? I also need a new speedo sensor that may be activating the oxygen sensor light (so i might not need an oxygen sensor). Should i get a Honda sensor or just go with the one at Autozone if i save like 50 bucks?
Thanks For Your Help!!!
Old Aug 31, 2007 | 12:01 PM
Maharajamd's Avatar
Default Re: Oxygen Sensor Replacement (Mike1995HondaPrelude)
I would just buy a OEM honda part. And its a pretty easy install. Just have the proper tools.
Denso, NGK is good if you don't go OEM. But def don't buy a bosch lol...
Old Aug 31, 2007 | 12:06 PM
Default Re: Oxygen Sensor Replacement (Maharajamd)
lol. ok thanks for your help
Old Aug 31, 2007 | 12:12 PM
did you mean NTK?
Old Aug 31, 2007 | 12:16 PM
no1knows908's Avatar
Anyone ever experienced a Bosch O2 sensor giving a incorrect signal? I changed mine a few months back when it went out with a Bosch and it runs really rich. I checked or changed everything I could think of that would be causing a rich condition. I'm going to try cleaning out my EGR valve to see if it helps. Oh and one more thing, I had to changed the O2 twice because the NEW Bosch sensor I installed sh*t itself less than a month later. Autozone swapped it under warranty, otherwise I would have ordered the Denso. I checked the MAP and IAT sensor; also changed the coolant temp sensor, fuel pressure regulator, plugs, wires, cap, rotor, air filter, PCV valve. I'm suspecting the "new" Bosch sensor may be defective... Would using a test pipe affect the functionality of the O2 sensor with OBD1?
Old Aug 31, 2007 | 12:24 PM
Maharajamd's Avatar
Ok lets make this simple. Bite the bullet, and get a oem one. You won't have to worry about it for a looooooong time.
Old Aug 31, 2007 | 12:27 PM
E-Money's Avatar
Default Re: (Maharajamd)
do the O2 sensors come with the harness plug or you have to solder the wires?
Old Aug 31, 2007 | 12:28 PM
Yea that would be the easiest way... But whose to say the "new" bosch isn't bad and I just wasted my money on a new one.
Old Aug 31, 2007 | 12:31 PM
Maharajamd's Avatar
I just bought a new bosch 2 months ago. 2 weeks later is screwed up. I returned it, and ordered #23...
http://www.hondaautomotivepart...YSTEM
Old Aug 31, 2007 | 12:47 PM
Yea my first one made it 3 weeks. I'm just hoping this whole time that it wasn't the o2 giving the ECU a false signal.
Old Aug 31, 2007 | 01:50 PM
dagle's Avatar
Default Re: (no1knows908)
i have a bosch one u guys can dissect if u want lol, i got an OEM one from a wrecked car w/ low mileage.. waiting to put that in. my bosch is plugged in but not connected to anything. its just sitting there and i have the o2 sensor code (cuz its not hooked up)
Old Aug 31, 2007 | 02:11 PM
chitownrida's Avatar
i went the cheap route and bought a bosch from ebay.. never had a problem with it make sure you trim the wire length accordingly.. and it wont throw a code
Wildemanam
Honda CR-V & Element
Jan 30, 2018 08:58 AM
dez6
May 17, 2013 01:29 AM
psal
Oct 2, 2008 02:53 PM
vtecjb
Mar 30, 2007 10:39 AM
diyer
Aug 9, 2004 02:36 PM
