Help Alternator Problem
Old Oct 17, 2007 | 11:19 PM
yoogidc4's Avatar
Default Help Alternator Problem
ok i have an jdm h22a in my eg hatch every time i get a different new battery all the power from the battery drains within a day ,i have changed my alternator about 3 times already but they were all used alternators ,would anyone know what the problem would be , would it be that i should get a brand new alternator or what? thanks
Old Oct 17, 2007 | 11:27 PM
Hawkze_2.3's Avatar
Default Re: Help Alternator Problem (yoogidc4)
Start testing the individual wires according to the helms manual and you will be able narrow down your problem.
Old Oct 18, 2007 | 05:37 AM
mgags7's Avatar
That thing looks like a wiring mess. What wiring did you do for the alternator and starter and such?
Old Oct 18, 2007 | 09:12 AM
JT's Avatar
JT
There might be a drain somewhere in the electrical system. Connect a volt meter to the battery terminal and monitor the voltage readings when the engine is idling, around 3000 rpm and engine off. The voltage should be between 12.5 to 14.5 when the engine is running. Turn the engine off and monitor the voltage drop. If the voltage continues to go below the normal battery voltage (~12vdc), then you have a drain. Start with any add-on connections or accessories by disconnect them one at a time until the voltage drop stops. If no problem found there, then move on to the fuse box to track down which circuit is causing the problem. Pay attention if you have tapped into any fuse proctected circuits.
Old Oct 18, 2007 | 10:17 AM
yoogidc4's Avatar
Default Re: Help Alternator Problem (JT)
yeah the voltage drops when on idle ,drops even more when i put the lights and ac on
Old Oct 18, 2007 | 10:19 AM
yoogidc4's Avatar
yeah i know the wiring is all crappy got it like that
deathdillan
Apr 28, 2014 02:03 PM
hondastrtracr
16
Jan 27, 2008 09:16 PM
ID_ten_T
Nov 2, 2004 11:24 PM
X-Static
15
Jun 7, 2004 07:36 PM
esoterEK..
Mar 8, 2004 10:58 AM
