Check engine light . . .
Old Oct 13, 2007 | 08:09 AM
leemikemphstn's Avatar
Default Check engine light . . .
My check-engine-light came on last night. I had it diagnosed and the computer read-out was "EGR air flow diminished". The tech said it was probably the EGR going bad. My '98 Prelude has 129,000 miles. Does anyone agree that this technician is (most likely) correct? If so, any suggestions where I can buy one for less than the $209.00 they'd charge me?
Old Oct 13, 2007 | 08:41 AM
fastpreludezip's Avatar
Default Re: Check engine light . . . (leemikemphstn)
um i think egr has to do with exhaust leak.....does it sound like u have an exhaust leak....i could b wrong
Old Oct 13, 2007 | 08:44 AM
Hawkze_2.3's Avatar
Default Re: Check engine light . . . (fastpreludezip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastpreludezip &raquo;</TD></TR><TR><TD CLASS="quote">um i think egr has to do with exhaust leak.....does it sound like u have an exhaust leak....i could b wrong</TD></TR></TABLE>
Yeah, you're wrong The EGR flow is probably 'diminished' because it just has a lot of build up inside...it happens all the time. You can remove it and clean it out and also try to clean any of the ports that you can and that should help with the CEL. Also try searching fo other threads on how to clean the EGR valve.
93cavRS
19
Aug 6, 2006 02:03 PM
eluder33
Jun 5, 2006 12:48 PM
Arsenal
Apr 8, 2006 10:28 PM
simbotto
Oct 23, 2005 07:35 PM
HyperITR742
Jul 13, 2003 09:25 AM
