HELP! amp: Firewall?
Old Oct 11, 2007 | 08:23 AM
akprelude99's Avatar
Default HELP! amp: Firewall?
i'm looking to install an AMP into the 99 lude. in my old car, i found a hole in the firewall so i just ran the power cord through it, but i couldn't find a hole in my prelude's firewall. is there a precut hole running through or would i have to drill one? any other alternatives? people with 5th gen preludes please respond with your knowledge?
Old Oct 11, 2007 | 08:56 AM
scottblade's Avatar
Default Re: HELP! amp: Firewall? (akprelude99)
Well last time I did it on my last Prelude I did not find a hole so I just made a hole through the rubber. But be careful and dont let the cable get sandwiched between metal. I could have been wrong in making a hole but this is how I have done it on my past 3 cars.
Old Oct 11, 2007 | 09:15 AM
Default Re: HELP! amp: Firewall? (scottblade)
i couldn't find any rubber to make the hole through. i looked and it looked solid
Old Oct 11, 2007 | 11:41 AM
Acidcrakker's Avatar
Look for other wires running into the firewall. There should be atleast 1 or 2 there. SO look carefully you should be able to squeeze the power cord through one of them
Old Oct 11, 2007 | 11:50 AM
smo0th's Avatar
Ok there are two rubber insolators where the wires run through the fire wall. They are located under your fuse box, so you will have to remove the screws holding it down to move it out of the way.
Next you will need to get a coat hanger and straighten it out. Then duck tape the power wire the end of the coat hanger. Next just push the coat hanger through and go to your glove box and find the coat hanger to finish pulling it all the way through. It will be easier if you can get someone to help you feed the wire through. Good Luck
Old Oct 11, 2007 | 12:02 PM
manbearpig's Avatar
Default Re: (smo0th)
Easiest way for me was to go from my battery to inside my passenger's fender, through my fender, take my plastic inner fender out, and you'll see a gromet where wires are already running through into the cab, run it right there and it sticks out right on top of your ecu.
Old Oct 11, 2007 | 12:03 PM
manbearpig's Avatar
Default Re: (mang.)
oh and no coat hangers, or duct tape, or anything other than your hands and a screw driver for this one.
Old Oct 11, 2007 | 12:57 PM
Default Re: (mang.)
i dont think this is recommended...or if someone said it about the passenger fender, but in a different car, i ran it from the hood, through a small opening of the car and the quarterpanel, straight into the car..and then ran the wire under the floor mat. bad idea?
Old Oct 11, 2007 | 01:00 PM
TylerC161's Avatar
Default Re: (akprelude99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akprelude99 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think this is recommended...or if someone said it about the passenger fender, but in a different car, i ran it from the hood, through a small opening of the car and the quarterpanel, straight into the car..and then ran the wire under the floor mat. bad idea?</TD></TR></TABLE>
Like, through the door jam? Im confused. If so, yes, thats bad.
Ill tell you the BEESSST way to wire up an amp.
Relocate your battery to the back, and run a single &lt;2 feet power wire to the amp.
Old Oct 11, 2007 | 01:18 PM
manbearpig's Avatar
Default Re: (TylerC161)
lol, then he has to worry about running the wire back up front Try what i said, did it on my 5th gen 2 days ago, easiest car I've ever wired.
Old Oct 11, 2007 | 01:21 PM
Default Re: (mang.)
i kinda don't understand the difference between my way and ur way. it sounds like we did the same thing?
Old Oct 11, 2007 | 01:32 PM
arkosh.kovash's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smo0th &raquo;</TD></TR><TR><TD CLASS="quote">Ok there are two rubber insolators where the wires run through the fire wall. They are located under your fuse box, so you will have to remove the screws holding it down to move it out of the way.....</TD></TR></TABLE>
did this myself. no problem at all.
-and there is nothing wrong with fishing wires with a coat hanger and duct tape. seen many of professional electricians fish wire with the like
Old Oct 11, 2007 | 01:46 PM
manbearpig's Avatar
You are talking about running it where the door will shut on it... am i correct? i think thats what you are saying, take off the inside of your fender (like 3 plastic screws is all you need to take off, you'll see a gromet with wires already going through it.... run it through there, and it comes out right on top of your ecu.
Old Oct 11, 2007 | 01:47 PM
manbearpig's Avatar
Default Re: (arkosh.kovash)
never said there was anything wrong with coat hanger and duct tape, i've done it many times.... but this way he does not need to fool with that.
Old Oct 11, 2007 | 02:49 PM
* B A N N E D *
Default Re: (mang.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mang. &raquo;</TD></TR><TR><TD CLASS="quote"> need to fool with that.</TD></TR></TABLE>
well needing to fool with stuff usually doesn't imply agreement.
e.g.
you also shouldnt fool with running the power/ground/speaker wires together to the amp or you will end up with ground noise on the output end
Old Oct 11, 2007 | 04:53 PM
Slatelude's Avatar
rubber plug behind the underhood fuse box, pull that, drill a hole in it apropriate size for wire(s), I ran my "0" gauge power wire through it. Slide your wires through there, and now the once plug, acts as a water tight gromet! I just cant bring myself to run wires through the fenders.....considered it.....just too exposed, but if it works for ya, then cheers.
Old Oct 23, 2007 | 12:16 PM
Default Re: (Slatelude)
could i see some pictures of how you guys ran your power wire?(in detail) so i will not be confused whatsoever? thanks.
Old Oct 23, 2007 | 12:29 PM
Dude its really easy, you are making it harder than it seems. I did it to my last 4th gen. I know you have the 5th gen but the theory is still the same.
1. There is a hole or two on your firewall with wires running through it. That is how you will get the power wir into the cabin, what ever way you choosse to get it through the hole is on you. I rripped up my carpet and ran the wire under that along the driver side into the trunk.
2. Your remote wire and RCA Cables can be run together to the truck same way under carpet along driver side into trunk.
3. Ground wire is easy, just find somewhere in trunk that can work good.
Its easy try not to think about it to much.
Old Oct 23, 2007 | 12:34 PM
Default Re: (Acidcrakker)
the only problem with that is that i cannot find a hole to run it through. as much as i looked. and i looked almost everywhere. even from in the inside of the car, i can't see a hole. it seemed to me that it was all closed off. thats my problem. if i could find the hole then this thread would have not been posted in the first place.
Old Oct 23, 2007 | 12:58 PM
Well there has got to be. Here is another IDea, but it probally wont be the brightest idea to do. Run you wire from battery to bottom of chasis. Use zip ties to safely tie the power cord to the fuel line rails. Run it all the way to the trunk using zip ties and find a drian hole that is in your trunk. It will have a rubber plug in its way. Poke plug out, cut hole big enough to get power wire through plug and ta da.
Warning if you do this and hit a bump that severs the power line and it shorts and burns through your fuel line and blows the car up with you in it, dont come crying to me cause Ill just say ''TOld you so''
Make sure you install proper fuse to.
Old Oct 23, 2007 | 01:02 PM
hahahaha. i heard of a professional installation place that ran wires under the vehicle. i'm not 100% sure but thats word of mouth. it doesnt sound too bright. anyway, i guess all i can do is just look harder to find the hole in the firewall, i really cannot find one ANYWHERE. do u know the general area of one? cuz it really did look all sealed off. i canot even find where other wires are at that i could feed thru with them.
Old Oct 23, 2007 | 01:14 PM
powerdbygarrett's Avatar
i just drilled a hole a little above the clutch and as much to the left as i could so it would not be visible
Old Oct 23, 2007 | 01:18 PM
What you have to look for is probally a black wire tube. It holds wires in it. They are all over your engine bay. But this ne will probally run into your firewall and conect to a ruber plug as well. Or what you can do is look in your cabin under driverside where the pedals are and see where the wires are coming in at.
Old Oct 23, 2007 | 01:20 PM
my battery is in the front passenger side of the hood. yours too? that seems like a long way to run the wire through the engine. wont it get HOT?
Old Oct 23, 2007 | 01:25 PM
Use common sense dont wire through the engine or any moving parts. I cant help you anymore than this. For real dude goodluck, but have a profiessional install it cause It dont seem like you know whats what.
