3g overheating problem.
Old Oct 16, 2007 | 09:45 AM
prettyinpink's Avatar
New User
Default 3g overheating problem.
i have an 89 2.0 Si and its overheating.
it takes about 15-20 minutes for it to actually start overheating.
once i turn the heater on it will stop. atleast until the next time i drive it.
i replaced the thermostat about two months ago so it should be fine. and even if it was the thermostat again it would overheat in a matter of a couple minutes.
ive also bled the coolant lines. until there was no air whatsoever. before we did this one of the hoses was completely dry. so im not sure why that was.
we also put a toggle switch for my fans in. and still. it still overheated and when i turned the fans on it didnt cool it down at all, the temperature actually kept climbing.
so i have noooooooooo idea what to do next.
im guessing it might be my water pump? not enough (or any) water getting to the engine? what do water pumps act like when they go bad? i have no experience with these but i heard its a pain and a half to put in.
is there anything else you guys can think of before i go through all the trouble?
Old Oct 16, 2007 | 10:06 AM
Hawkze_2.3's Avatar
Default Re: 3g overheating problem. (prettyinpink)
Bleed it more using the bleeder screw and the radiator.
Old Oct 16, 2007 | 01:06 PM
bigluelok's Avatar
Default Re: 3g overheating problem. (Hawkze_2.3)
since you have a 3rd gen check out http://www.preludepower.com they have alot more 3rd gen ludes
yeah try to blead it using the bleeder screw and also check for clogged hoses and make sure the hose under the intake manifold is still in takt
Modified by bigluelok at 2:42 PM 10/16/2007
Modified by bigluelok at 2:43 PM 10/16/2007
Old Oct 16, 2007 | 03:23 PM
slamdlude's Avatar
Default Re: 3g overheating problem. (bigluelok)
The radiator is probably clogged.
Joshable14
Jul 20, 2015 10:10 AM
nonvtec92
14
Nov 28, 2008 04:50 PM
helldriver88
Jan 26, 2008 10:33 PM
dc2415
Jul 1, 2007 08:51 AM
christiian
18
Jul 16, 2006 12:03 AM
