ATTS light is on?
Old Oct 16, 2007 | 08:38 PM
Tunerguy1989's Avatar
Default ATTS light is on?
What are some common causes for this light to be on. My car is running fine so im assuming that it is a sensor but im curious if anyone has any more info that they can give me. Sometime tanny gets jammed, it doesn't let me go into first unless i pump the clutch is that normal or due to high mileage.
Old Oct 17, 2007 | 05:06 AM
integra15's Avatar
Default Re: ATTS light is on? (Tunerguy1989)
The ATTS light goes on every time the the MIL(check engine) goes on. Either way you should read the code and start there.
Old Jun 24, 2009 | 02:24 PM
I recently changed the fluid in my atts unit. the light turned off for about 20 min then turned on again. I installed a cooler for the unit so I'm thinking it might just need more fluid because the aftermarket cooler takes in more then the oem one did. What are common reasons for the light to come on.
My car runs fine even when I run it hard, but I'm just tired of seeing that light on.
Any input would be appreciated
Old Jun 24, 2009 | 02:41 PM
Kronn 98SH's Avatar
Throw a dart at the underside of your car. Whatever the dart hits is causing the problem.
That method is far more accurate than asking for our guesses.
Read it. https://honda-tech.com/forums/showthread.php?p=38252637
Old Jun 25, 2009 | 10:25 AM
blumpkinBB6's Avatar
one time the ATTS light only came on for me because the oil pressure regulator on the left side went out so i had to have it replaced, about 300 out the door
Old Jun 25, 2009 | 01:48 PM
ceezo70's Avatar
low air tire pressure, running diff size wheels/rims...everytime engine light comes on atts light will come on, fix and clear code...low fluid in atts, sensor, too much horsepower but i doubt that's the case..can be going bad, or a sensor
Old Jul 3, 2009 | 05:52 PM
My check engine light was on I checked the code and it was a bad O2 sensor. I changed it the light went off but my ATTS didn't go away. O well if my car starts actin up Ill just take in to get it checked out. It would be to much of a headache for me to take out the unit.
Old Jul 3, 2009 | 06:39 PM
Kronn 98SH's Avatar
You obviously didn't look at the link I posted.
Cameron707
Apr 11, 2017 10:17 PM
MADDIESMOMMY760
Nov 18, 2012 07:34 PM
YaMaJeSty
Honda Motorcycles
Feb 9, 2008 12:47 PM
Markov
Jan 25, 2006 10:13 AM
Corruption
Sep 27, 2005 07:09 PM
