power steering having issues
Old Oct 10, 2007 | 09:59 AM
thepel's Avatar
Default power steering having issues
ok so i have a '94 prelude with a h22a vtec and the power steering pump went out yesterday so i went and got a new rebuilt one from my shop and swapped it out. after all of that i find out today that there is air in the system, I took it in to the shop today and they fixed that problem. but now the steering doesn't feel like its acctualy getting any more than 25% power. It's like driving it with just non-power steering. Any Thoughts?
Old Oct 10, 2007 | 10:28 AM
mattsnooz's Avatar
Default Re: power steering having issues (thepel)
No whinning noise from the pulley or belt?
Hold a stethoscope up to the pump and listen. If you hear any grinds or clunking the pump insn't good.
Did you change the power steering fluid?
Maybe the valve comming off the pump isn't opening all the way??..
Its a hydraulic valve right by the pump inline with the ps lines.
Old Oct 10, 2007 | 12:28 PM
thepel's Avatar
Default Re: power steering having issues (mattsnooz)
the pump is good we listened to it today. and they bled the system and refilled the resivior.
Old Oct 10, 2007 | 01:47 PM
mattsnooz's Avatar
yeah, than like i said, check that flow valve thats inline with the powersteering line
Old Oct 10, 2007 | 01:53 PM
Duane_in_Japan's Avatar
Is it an OEM rebuild, there is a valve in the bottom of the pump, it is probably bad, ask for another rebuild.
Old Oct 14, 2007 | 11:51 AM
thepel's Avatar
Turns out my power rack is leaking and needs to be replaced. thanks for the advice though
smcdonaldaz
Acura TSX
Dec 10, 2019 01:21 PM
surf40
Jan 5, 2018 11:53 AM
blackj30_a
Sep 4, 2016 06:01 PM
tominos
Feb 25, 2004 04:32 PM
