Adjusting distributor
When adjusting a distributor what angle are you supposed to look at to line up the pointer and the marks on thel flywheel? I tried to get as close to 90 degrees to the inspection hole as I could, just making sure I was right
i've got a timing light, if you look through the inspection hole at different angles, the position of the marks in relation to the pointer will change
Just try to look from as straight above as you can judge. Where the light beam is perpendicular to the flywheel surface and the little pointer.
Warren_LowSol
Jan 18, 2018 12:22 PM
honda3431
Dec 23, 2007 11:05 AM
