Ignition Problem?? H22 EK
Old Oct 12, 2007 | 06:45 PM
JManny's Avatar
Default Ignition Problem?? H22 EK
So I changed the spark plugs and wires to my car today with some ngk wires and iridium plugs and when I took it for a test drive at about 3k rpm the car started to shake weird and didnt have a lot of power but it still climbed rpm's. I thought I put a wire in the wrong plug but I checked everything and I even replaced the wires with the stock ones and it did the same thing. So I put back the old plugs too thinking if maybe that was it but it still did it??
So I dont know what it might be if everything was fine before I changed them. Im going to take it to a shop tomorrow so they can look at it but what do you guys think it is? Its still driveable but that weird shake and less power has me worried.
Its a 97 ek with an h22. It has an MSD 2 step if that helps.
Thanks.
Old Oct 12, 2007 | 06:56 PM
ALLMOTORH22A's Avatar
Default Re: Ignition Problem?? H22 EK (JManny)
make sure ur firing order is correct, and the distributor isnt 180 degress off
Old Oct 12, 2007 | 07:03 PM
JManny's Avatar
Default Re: Ignition Problem?? H22 EK (ALLMOTORH22A)
but just changing the plugs and wires affect the firing and distributor?
Old Oct 13, 2007 | 07:27 AM
dustin_bb6's Avatar
check the order the plug wires are in on the distributor because they might have got mixed up..
Old Oct 13, 2007 | 10:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JManny &raquo;</TD></TR><TR><TD CLASS="quote">but just changing the plugs and wires affect the firing and distributor? </TD></TR></TABLE>
yes it can... u'll be suprise on how many people make this mistake.. i have a couple of times... sometimes u got the wires right but the distributor key (part that goes on the end of cam shaft) could be 180 degress off and cause it to mis fire like wut u are discribing how the whole car shakes... u could try turning it 180 degress b4 u mess wit the plug wires to see if that helps, but make sure ur firing order is correct first
Old Oct 13, 2007 | 10:33 AM
bluedlude's Avatar
what makes everyone think he took off the distributor to change the plugs and wires?
if you know plugs and wires are good and that they are connected well, whats left?.....
Old Oct 13, 2007 | 03:06 PM
JManny's Avatar
Default Re: Ignition Problem?? H22 EK (bluedlude)
yeah i did not take off the distributor but i will try turning the dis key 180 degrees to see if thats it. thanks
Old Oct 13, 2007 | 03:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">what makes everyone think he took off the distributor to change the plugs and wires?
if you know plugs and wires are good and that they are connected well, whats left?.....</TD></TR></TABLE>
becuz of the problem he discribed.. happended to me and thats wut the problem was.. was a pain to figure out.. i thought my car was f'ed
Old Oct 13, 2007 | 03:16 PM
Rabid Machina's Avatar
check the gap in your plugs and try using your old plug wires see if the problem still happens. you did say this all happend after you changed the plugs and wires?
1fastlude1
Sep 12, 2011 04:22 AM
B18dudeg
Feb 10, 2011 05:51 AM
MonKK
Jul 9, 2008 03:06 PM
JManny
Oct 12, 2007 07:42 PM
crfr230
Mar 11, 2007 05:48 PM
