is this the right compression testor for H22 ?
Old Oct 18, 2007 | 07:46 PM
yohan's Avatar
Default is this the right compression testor for H22 ?
and if so, how do i screw this thing in and know its making a good seal?
Longass rubber hose ...
Old Oct 19, 2007 | 09:29 AM
117's Avatar
117
The o-ring will make a good enough seal. My compression tester has the same type of setup. Make sure you have the right fitting for you spark plug hole (IIRC, M14x1.25).
Old Oct 22, 2007 | 05:08 AM
Lubo_25's Avatar
Default Re: is this the right compression testor for H22 ? (yohan)
looks like a nice piece...you can if you want put a little vaseline on the o-ring to make sure she seats nicely and not dry other than that just screw her in(dont forget to take out your fuel pump fuse)
Old Oct 23, 2007 | 08:59 PM
yohan's Avatar
thanks for the replies guys, my main concern was if hand tightening it would be good enough.
Old Oct 23, 2007 | 09:00 PM
Hawkze_2.3's Avatar
Default Re: (yohan)
Yeah, I have that same type of tester and hand tightening it always works fine.
Old Oct 24, 2007 | 05:13 AM
PirateMcFred's Avatar
Make SURE that all the fittings on the end of the hose are tight. I have had them come apart when they're down in the sparkplug well. It was unpleasant to get them out.
Also the more hose between the head and the valve/gage will yield a lower pressure since the volume of the hose will be like adding volume to the combustion chamber. Shorter hoses will be more accurate.
alex14
10
Dec 3, 2010 02:16 AM
hometheaterman
Apr 3, 2010 10:44 AM
h224thgensedan
Apr 24, 2008 12:11 PM
vegas hoe
Feb 16, 2008 05:06 AM
typer_801
Feb 5, 2003 01:12 PM
