hellp jdm headlights install
Old Oct 15, 2007 | 08:54 PM
lilazn71's Avatar
Default hellp jdm headlights install
ok so i have jdm one piece to install but i cant even get my original oness off the frame and the bumper support is in the way is there anyway to remove the bumper support or an easy way to get my stock ones off?
Old Oct 15, 2007 | 09:14 PM
snobordboy's Avatar
Moderator
Default Re: hellp jdm headlights install (lilazn71)
theres a how-to out there, follow its steps and your golden.
Old Oct 15, 2007 | 09:24 PM
prelude_93vtec's Avatar
hey. next time, please use the search button. people usually get flamed for not using it lol. anyways i found a link for you
http://www.absoluteprelude.com...ID=45
Old Oct 15, 2007 | 10:08 PM
preludefien
Guest
Posts: n/a
Default Re: hellp jdm headlights install (prelude_93vtec)
agreed
Old Oct 15, 2007 | 10:14 PM
M2B4's Avatar
on a more serious note. if ur having problems installing headlights...maybe read up more about DIY's before attempting other DIY's.
note: on the wiring I "double grounded" ( took the extra wire from the 3 wire socket and grounded it with the negative on the 2 wire socket) and it made my lights a bit brighter. just a tip
Old Oct 16, 2007 | 03:33 AM
cb7tougeracer's Avatar
Default Re: hellp jdm headlights install (M2B4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 &raquo;</TD></TR><TR><TD CLASS="quote">
note: on the wiring I "double grounded" ( took the extra wire from the 3 wire socket and grounded it with the negative on the 2 wire socket) and it made my lights a bit brighter. just a tip</TD></TR></TABLE>
for mine i just got the part from passwordjdm.com plugs in to stock then into jdm then done
Old Oct 16, 2007 | 04:00 AM
prelude_h22vtec's Avatar
bumper support must be removed
Old Oct 16, 2007 | 06:47 AM
lilazn71's Avatar
Default Re: (prelude_h22vtec)
oh well i was just wondering how to get off the bumper support like how many bolts
Old Oct 16, 2007 | 02:09 PM
Apex1972's Avatar
Default Re: (lilazn71)
2 bolts are removed from each side of the front, I think they are 12mm.you will find it easier with a long extension and socket. behind each headlight there are a 12mm nut. You might want to remove your battery and power steering unit out of the way. While your at it, just remove anything that you feel isn't needed and it will be easier to get to everything.
Old Oct 16, 2007 | 02:30 PM
JDMLude850's Avatar
just go ahead and pull out your engine also.
vivithemage
15
Mar 14, 2007 11:37 AM
97itypeR
Nov 15, 2006 02:38 PM
etnavyman
Apr 24, 2004 02:56 PM
ef93si
Dec 6, 2003 09:18 AM
90da
Sep 19, 2003 05:10 PM
