heat control light
Old Oct 31, 2007 | 05:00 PM
charles1's Avatar
Default heat control light
anyone know what the heater control light bulb size is in the 4th gens? i was assuming it was a 74 just like the instrument panel.
Old Nov 1, 2007 | 03:55 AM
sean1121's Avatar
Default Re: heat control light (charles1)
Look it up:
http://www.hondaautomotiveparts.com/
Old Nov 1, 2007 | 04:13 AM
smackdown's Avatar
mine does go on and off somtimes only heater / fan speed controls has no lights what could cause this anybody.. thanks
Old Nov 1, 2007 | 04:36 AM
charles1's Avatar
Default Re: heat control light (smackdown)
i took mine out and found that one of my bulbs was burned out.... and that some of the solder joints had cracked
Old Jan 27, 2008 | 07:28 PM
natedawgrules's Avatar
This might sound like a dumb question but, what on the climate control untit should be illuminated with lights on.
My '96 only lights the temp slider, the fan speed slider, the A/C button and the Rear defrost button. The Mode switches don't illuminate however the leds that idicate which position is on work fine. Do I have a bulb out or do I need to resolder everything like I keep reading?
Old Jan 27, 2008 | 08:00 PM
prelude_93vtec's Avatar
Default Re: heat control light (natedawgrules)
Ya sometimes i gotta like hit mine to make it come on. I think i have a loose ground somewhere
Old Jan 29, 2008 | 07:52 PM
Default Re: heat control light (prelude_93vtec)
So the mode buttons are actually supposed to be lit?
Old Feb 1, 2008 | 10:45 PM
MLBZ521's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_93vtec &raquo;</TD></TR><TR><TD CLASS="quote">Ya sometimes i gotta like hit mine to make it come on. I think i have a loose ground somewhere</TD></TR></TABLE>
The Green Harness is most likely your problem. The Socket on the Circuit Board has cracked Solders most likely. What was wrong with mine. Quick, simple fix. It'll be harder to take it apart and put back together.. A lot of work to do that, but no more problems or shorts..
If you look here: http://www.hondaautomotivepart...NTROL
The Bulb #1 is what illuminates the Buttons and the Temperature & Fan Speed Sliders. There are three of these on the Control Unit. Two for each side of buttons and one for the Sliders.
The Two that illuminate the Buttons on mine are out.
The Colored Lights, Green & Amber, for each switch are separate LEDs.
What's in my Control unit is not normal LEDs though, and I couldn't find them at the Radio Shack I checked.. And for $2.99 from Honda, that's kinda expensive..
Red_ED8
Feb 7, 2008 10:35 AM
T_bones
Nov 3, 2005 01:49 PM
AndyD
May 2, 2005 09:15 AM
remo
Jan 15, 2005 02:16 PM
Pr0jektLude
Aug 15, 2004 07:11 PM
