knock sensor
Old Nov 5, 2007 | 12:47 PM
Apex1972's Avatar
Default knock sensor
Last night , about 12:30 A.M. I got a CEL. It was 23, I reset this morning and so far it has not come back on. Why would the knock sensor throw a random code like this unless something may be loose?
Old Nov 5, 2007 | 01:05 PM
MilanoLude's Avatar
Default Re: knock sensor (Apex1972)
My knock sensor broke into two pieces where the plastic joins with the metal and randomly threw that code.
Simply resetting the ECU won't be the fix if the connection is bad, it will probably come back on.
I did the same thing and the CEL stayed off for a day so I figured everything was okay. But the CEL came back on again so I reached up there and the top plastic piece pulled right out.
Old Nov 5, 2007 | 02:03 PM
Apex1972's Avatar
Default Re: knock sensor (MilanoLude)
yeah, I guess I just gotta break down and buy one.
Old Nov 5, 2007 | 06:17 PM
Lude17's Avatar
I just had to purchase one of these. The dealership quoted me something like $177. Picked one up on eBay instead. I just looked there's a few on there for a lot less, which is where I got mine. Just a heads up.
Old Feb 11, 2008 | 09:55 AM
Apex1972's Avatar
Default Re: knock sensor (Lude17)
OK, I have replaced the knock sensor with a brand new one. I looked at the plug, it looks fine. I still get the CEL . It will come on every week or so. When I reset it, it is fine again until a few more days. What else could be the problem? Is it poosibly something inside the ECU going wrong?
Old Feb 11, 2008 | 10:01 AM
royalfelix's Avatar
are you sure its on there good? maybe when u hit a big bump it comes a little lose or something...
Old Feb 11, 2008 | 10:22 AM
98vtec's Avatar
moderator emeritus
Default Re: (royalfelix)
if you have a service manual, you can test everything with a multimeter to see if everything is in check.
Old Feb 11, 2008 | 10:33 AM
xxmastermindxx's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
x2. if you got a new knock sensor, and it's doing the same thing, you might have an intermittent open or short in your wire somewhere. service manual tells you which wire at the ecu to check with your meter.
Old Feb 11, 2008 | 12:37 PM
Apex1972's Avatar
Default Re: (xxmastermindxx)
what if you don't have a service manual? and yes, I checked the connection yesterday and it is plugged in tightly.
Old Feb 11, 2008 | 01:42 PM
Apex1972's Avatar
Default Re: (Apex1972)
Old Feb 11, 2008 | 03:29 PM
drbenne's Avatar
download one..
http://www.sfpoa.net/forum/showthread.php?t=4518
Old Feb 12, 2008 | 09:55 AM
Apex1972's Avatar
Default Re: (drbenne)
thanks man.
Kangolbrand
Aug 23, 2006 09:23 PM
VTECth1s
Aug 20, 2006 02:16 PM
oranginal
Jul 6, 2006 02:17 PM
hybrider
Feb 21, 2003 09:50 PM
