need help again....
Old Nov 9, 2007 | 03:38 PM
FlyingDaggers's Avatar
Default need help again....
after the h22 swap.....how come the oil light is on??? was it connect to the wrong plug or what...can someone give me a headsup on that....??? i could use all the help i can get...but no smart asses.....don't need those people replying..thanks
Old Nov 9, 2007 | 03:51 PM
mgags7's Avatar
From now on title your threads more appropriately to what your topic is.
Check the sensor, make sure the wire is attached to the switch soundly, check resistance back the ecu pin. If that all checks out fine then you actually have low oil pressure.
If so, pull the pan off and clean out the pickup.
88turdbucket
Jan 17, 2009 05:13 PM
jpeso23
Jun 14, 2008 09:22 AM
tank62
Nov 21, 2007 04:34 PM
djsire
Aug 11, 2006 02:24 PM
st0nedstoopid
Aug 19, 2003 06:43 PM
