checking cel
Old Nov 8, 2007 | 03:50 PM
crank.it's Avatar
Default checking cel
hi guys -got a 93 lude need to know how to pull cel codes....manual says go to connector behind console jump pins and watch for flashes????recently boosted and cant get to run correctly for tunning.........thank in advance....crank.it
Old Nov 8, 2007 | 05:01 PM
boostedh22lude1's Avatar
Default Re: checking cel (crank.it)
the connector is under dash on drivers side by the console, its a 2 wire connector and its blue u put a jumper wire in it, turn the key on and it will flash ur codes
Old Nov 10, 2007 | 03:36 PM
crank.it's Avatar
Default Re: checking cel (boostedh22lude1)
thanks boosted guess I was on the wrong connector this one was behind console pinned to radio bracckett along side another connector...but thanks ill look again....crank.it
Old Nov 11, 2007 | 04:03 PM
crank.it's Avatar
hi guys looked again for the cel connector and the only two wire blue connector is the one that is pinned to the metal console????if this is it then it does nothing to the cel lite...any thoughts...why cel wont blink....crank.it
circapunk
Jun 7, 2009 09:32 AM
nemesis25
Jul 17, 2007 05:59 PM
O16581724 5 2 5
Nov 16, 2005 04:26 PM
Ricey McRicerton
Jun 18, 2003 11:55 AM
