high pitched sound
Old Oct 31, 2007 | 01:34 PM
94vtirozguy's Avatar
Default high pitched sound
guys i have a high pitched sound coming from the front right wheel area.
its not rotors, or pads (as they have been changed) and all the bolts are torqued to spec.
you can hear it driving in straight line, or turning and is intermittent.
It is light a high pitched metal noise.
Old Oct 31, 2007 | 02:24 PM
Burgiop's Avatar
Default Re: high pitched sound (94vtirozguy)
Perhaps it may be a wheel bearing.
Old Nov 1, 2007 | 01:39 PM
yeah it could be.. just want to rule anything else out before i check if it is the wheel bearing ...
Old Nov 1, 2007 | 02:16 PM
street_ride14's Avatar
Default Re: (94vtirozguy)
Check your assesory belts and make sure they're tight.
Old Nov 1, 2007 | 03:32 PM
Cottonwoodz's Avatar
Brake dust cover
Old Nov 2, 2007 | 06:36 PM
yeah its not a belt noise, and the dust covers are unscathed.
Old Nov 2, 2007 | 07:29 PM
Sampsonite987's Avatar
I would also say wheel bearing. Never had a problem on a Honda, but I had a '97 Nissan Maxima that would do it off and on. Never heard it when it was raining out but as soon as it dried up, I would hear it again. It usually subsided when I would brake and would be louder under acceleration but that would probably vary with the design. It started as a squeak and turned into more of a loud screeching groan, really annoying.
Old Nov 3, 2007 | 04:03 PM
thanks guys i will order then tonight
Newstarter
Honda Civic (2001 - 2005)
Jun 8, 2017 07:12 PM
sSandstorm
May 20, 2013 12:19 PM
dc4teg95
May 2, 2010 08:08 PM
dc4teg95
Suspension & Brakes
Apr 5, 2010 06:41 AM
pin3appel
May 26, 2009 07:51 AM
