Engine overheating
Old Nov 3, 2007 | 10:54 AM
generallee01's Avatar
Default Engine overheating
so my friend wants to buy this prelude but there is one problem with it and its that it overheats. Him and I are good friends of the owner, he said that he took out the radiator and flushed it out and it was flowing fine. Its not a head gasket because it doesnt smoke white and doesnt use anti-freeze. The oil pump is pumping oil so I know its not that. so Im guessing that something is blocking the line somewhere, or the water pump went. any sujestions? the car is in perfict condition and has no rust, engine runs perfict and nothing majorly wrong with it, just needs some clean up. the enigine is a B21A1. thanks.
Old Nov 3, 2007 | 10:59 AM
Acidcrakker's Avatar
Default Re: Engine overheating (generallee01)
What year is the prelude. Buy a water pump and swap it out to see if it works.
Old Nov 3, 2007 | 01:04 PM
JoHnSoN_JoHnSoN's Avatar
Default Re: Engine overheating (Acidcrakker)
Check the Basics:
Thermo-Stat
Rad. Hoses
Water Pump
Headgasket
Old Nov 3, 2007 | 01:05 PM
Sampsonite987's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">What year is the prelude. Buy a water pump and swap it out to see if it works.</TD></TR></TABLE>
You should definitely discover the prob. before purchasing it obviously, but make sure that you have settled on a price before you try and fix it. Running or not.
Old Nov 3, 2007 | 03:05 PM
yea, well Im not the one buying it so Im not too concerned about the problem. but yea, Im thinkin water pump. jw if you guys would have anyother sujestions. thanks.
LSBeast
Oct 9, 2006 07:31 PM
cadougherty_67
Mar 29, 2005 06:21 PM
Shakes
Acura TL, RL & ZDX
May 3, 2004 05:18 AM
quis23
Apr 21, 2003 09:54 AM
