Crank angle sensor location
Old Nov 20, 2007 | 08:51 AM
dumkopf's Avatar
Default Crank angle sensor location
Can someone point out the crank angle sensor on an H22 in a technical drawing. Searched everywhere for it. No clue what it would even look like.
Old Nov 20, 2007 | 09:56 AM
mgags7's Avatar
What year?
Old Nov 20, 2007 | 09:57 AM
mgags7's Avatar
In a 92-95 it will be in the distributor
96+ it is at the oil pump, the parts diagram is labeled oil pump/oil strainer or something like that...
Old Nov 20, 2007 | 03:30 PM
dumkopf's Avatar
So does that mean the 2 aren't compatible with each other.
Old Nov 20, 2007 | 03:34 PM
mgags7's Avatar
You can't use a 92-95 sensor on a 96+ engine without changing the distributor and wiring it to work.
You can't use a 96+ sensor on a 92-95 engine without changing the oil pump to a 96+ one and wiring that to work.
Old Nov 20, 2007 | 09:18 PM
dumkopf's Avatar
Default Re: (mgags7)
Where is this thing?
Modified by dumkopf at 12:56 AM 11/21/2007
Modified by dumkopf at 1:17 AM 11/21/2007
Old Nov 21, 2007 | 11:36 AM
bluedlude's Avatar
Default Re: (dumkopf)
like matt said, if you have a 92-96 the crank angle sensor will be in the distributor. if you have a 97-01 it will be on the oil pump housing.
Old Nov 21, 2007 | 11:37 AM
mgags7's Avatar
Default Re: (bluedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">like matt said, if you have a 92-95 the crank angle sensor will be in the distributor. if you have a 96-01 it will be on the oil pump housing.</TD></TR></TABLE>
Fixed
Old Nov 21, 2007 | 11:53 AM
dumkopf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
Fixed </TD></TR></TABLE>
Yeah, I have no idea where the oil pump is. A little help? Is it in the oil pan?
Old Nov 21, 2007 | 12:15 PM
mgags7's Avatar
It is behind the crank pulley, behind the lower timing cover.
That front end "snout" of the crankshaft comes right through the oil pump. To get at those sensors you'll need to take the crank pulley and lower timing cover off.
Old Nov 21, 2007 | 12:22 PM
dumkopf's Avatar
I've gotten this far. Now what?
Old Nov 21, 2007 | 12:23 PM
mgags7's Avatar
Take off that big gear on the bottom. That sensor you see on the left, along with the one on the right side, are all 1 unit.
Those are the sensors you're looking for.
Old Nov 21, 2007 | 12:25 PM
dumkopf's Avatar
How do I go about taking the gear off?
Old Nov 21, 2007 | 05:15 PM
SikB's Avatar
Remove the belt and pull it straight out. Don't lose the key though.
Chevy33
Feb 9, 2015 04:30 AM
jsteadman
Oct 27, 2014 12:42 AM
dawetnek
Mar 13, 2011 06:43 PM
schlong1
Oct 20, 2008 06:03 AM
schlong1
Oct 19, 2008 05:38 PM
