Rpm's hold while shifting????
Well i just picked up a 2000 Type SH and it runs great. But i did notice that when i shift, my rpms hold for a split-second and then drop. I tested it by holding my speed and then pushing in the clutch and let off the gas like i would be shifting and it does still. The only time it doesn't do it is while decelerating (off the gas or even slightly in it but still decelerating).
I hope this is enough info. I just don't remember my friends SH doing it and it makes shifting a little jerky. I'm use to driving a harsher clutch so maybe it's just me but i thought i'd check. Thanks
Here she is:
Here she is:
Re: Rpm's hold while shifting???? (Blacktt7)
My car does the same thing, i thought it was because of the fidanza flywheel, what could make a car do this?
Re: (Blacktt7)
its the ECU (from what ive found)
It makes it easier to land smooth shifts...
Now w/ a 8lb fidanza and a p28, my cars rpms drop almost to zero between shifts! it sucks!
Re: (98vtec)
oh, i dont think its a major problem, but it get annoying when you have a girl in the car , its like the car jumps foward between 1st and 2nd when shifting around 3000rpms.
Blacktt7 is it the same thing for you between 1st and 2nd?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 »</TD></TR><TR><TD CLASS="quote">its the ECU (from what ive found)
Now w/ a 8lb fidanza and a p28, my cars rpms drop almost to zero between shifts! it sucks! </TD></TR></TABLE>
Mine drops to like 500rpms and pops back up to normal idle really quick
moderator emeritus
Re: (DarkBB4)
go into crome and raise the ignition timing on the first two columns a couple degrees. Then raise the duty cycle of the IACV until it stops falling on its face.
Re: (DarkBB4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkBB4 »</TD></TR><TR><TD CLASS="quote">Now w/ a 8lb fidanza and a p28, my cars rpms drop almost to zero between shifts! it sucks! </TD></TR></TABLE>
Lol you gotta be the worlds slowest shifter, or you shift at 1k
* B A N N E D *
So adjust throttle cable? Mine's done this for a while, wasn't sure if it was my shitty 169k mile stock clutch or what.
I'll check it when I get the whip back.
Re: (ethereal2pt2)
Dono what all u smoking But this hapend in every prelude i ever drove (min of 10 dif one's) Had same thing in the one i have now. (this i know for 3rd 4th 5th Gen's)
, nope
, nope
Re: (mafia)
Mine does the exact same thing.
Seems logical enough. I'm sure lots of prelude owners don't shift as quickly as humanly possible all the time. You won't find many of those people here, but nevertheless..
* B A N N E D *
Re: (mafia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mafia »</TD></TR><TR><TD CLASS="quote">Dono what all u smoking But this hapend in every prelude i ever drove (min of 10 dif one's) Had same thing in the one i have now. (this i know for 3rd 4th 5th Gen's)
, nope</TD></TR></TABLE>
It obviously must do the trick if the competent members of the Prelude forum are suggesting to check it out.
Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">sounds like a problem with the throttle body.</TD></TR></TABLE>
That, or the throttle cable come to mind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz »</TD></TR><TR><TD CLASS="quote">
Lol you gotta be the worlds slowest shifter, or you shift at 1k </TD></TR></TABLE>
Yeah, I didn't get that either. I have an 8lb flywheel and I still have to wait a little while shifting for the rpms to come down.
Re: (LukieLuc)
I've just learned to shift a little slower and concentrate a little more on shifting til i get down. It never really learched forward. Just made for jumpy or over-reved shifts.
I'll have to check everything out to see if i can find anything tomorrow while i change my oil.
Thanks guys.....
Thanks guys.....
Re: (Blacktt7)
Noticed the same thing in my '97 SH. I just assumed it was the heavy stock flywheel keeping its' inertia once the clutch is engaged. Haven't actually tested it, but if this is true it should seem worse when depressing the clutch under WOT as opposed to just cruising (more momentum under acceleration). Anyone have experience with their stock AND replaced lightweight flywheel notice this phenomenon?
Yeah, I've had to learn to slow my shifts a little; with my short shifter I've had a couple nasty grinds from 1st to 2nd I think from shifting too fast
Re: (ECX)
Yeah my car's done the same thing ever since I've gotten it, and yeah the idle goes back down to about 500 rpms then goes up to normal. For whatever reason when I used to get a code for the tps and the cel came on, when I shifted the rpms would drop imidiately and the idle slowly glided down, I never did figure out why.
I did some quick looking around when i changed the oil a week ago but found nothing abnormal. I've just gotten used to it. It's nothing serious and it's probably just the way honda designed it.
RedlineShftr
02-19-2005 08:17 PM
