electrical problems
Old Nov 12, 2007 | 02:49 PM
97BB6Type-SH's Avatar
Default electrical problems
i finally finished my new front end and installed the headlights today. headlights and fogs work but the little city lights dont turn on. neither do my tail lights, but my brake lights work and so do my turning signals and reverse. also my dash doesnt turn on but all the little things lights the check engine lights and seatbelt and e-brake are on. i checked the fuses and didnt find anything wrong. How can i fix this? is it a fuse or a ground wire or what? Also, behind the drivers side headlight where the headlight wires come from theres a plug that i dont know where it connects to. maybe this is the answer to the problem but i can find where it connects to. and the plug only exist on the drivers side. any help? thanks
Old Nov 13, 2007 | 03:38 PM
Default Re: electrical problems (97BB6Type-SH)
can anyone help? all i need to know is where does that plug go connected to. its located behind the drivers headlight and comes with the wiring the goes to the headlight and it is grey. and it doesnt exist on the other side. the wires on it are real short so it must go plugged it somehwere close. anyone that wont mind looking at their 5th gen real quik can help me out alot. im pretty sure this is the answer to those things not lighting up, cuz i checked all the fuses. thanks
Modified by 97BB6Type-SH at 4:56 PM 11/13/2007
Old Nov 14, 2007 | 07:14 AM
????anyone
Old Nov 14, 2007 | 11:56 AM
mgags7's Avatar
You check the fuses both under the hood and inside the interior fuse box?
Your whole parking light circuit is blown.
Old Nov 15, 2007 | 06:51 AM
Default Re: (mgags7)
thanks. i found that the tailight fuse keeps blowing right away. i have a short circuit somewhere. they told me it must be a positive wire touching ground. same thing happened to my friends hatch and they told him the same. i just need to find that wire and i dont see it.
Old Nov 15, 2007 | 07:03 AM
mgags7's Avatar
Yep, I had a friend with the same problem, fixed his. He had some funky wiring for some fog lights up front, good luck finding yours.
Old Nov 15, 2007 | 07:13 AM
so the positive wire thats touching ground causing the short circuit can be from anywhere, like fogs etc? becuase my fogs and headlights work. its just my taillights, dash, and corner light insisde the headlight that arnt working. i do have sidemarkers wired up to those little corner lights . can it just be that those wires are touching metal? i hate electricity. any help would do. thanks
Old Nov 15, 2007 | 07:27 AM
mgags7's Avatar
No, the positive wire that is shorting out to ground has to be in this circuit, or else it would be blowing a different fuse.
Do you have <u>anything</u> aftermarket in that lighting system at all? Side markers? Gauges? etc.
Old Nov 15, 2007 | 04:46 PM
yea i have side markers. they have been on for about 6 months and then i crashed my front end and fix it. i already checked all those wires and see nothing loose or ripped or touching ground.
Old Nov 16, 2007 | 04:06 AM
mgags7's Avatar
I'm willing to bet you just need to check again. Stuff like this always happens in a crashed car.
jdmcivic1
Apr 23, 2008 08:27 PM
hypntcpimp
Jul 4, 2007 05:20 AM
TapOrSnap
Feb 23, 2006 03:15 PM
GSRfoedoe
Sep 17, 2004 09:11 PM
Ronin Panda
Oct 14, 2003 02:04 PM
