M2B4 losing reverse
Old Nov 18, 2007 | 01:00 PM
Dr.Honda's Avatar
Default M2B4 losing reverse
i just swapped my h22a w/ m2b4 into my cb7. the shidter felt a bit different from the f22 swap, but i didnt think anything of it. all week it ran hard with no problems. i was missing 3rd, but i just thought it was me getting use too the shifter.
yesterday at taco bell, i completely lost reverse. there were no symptoms or anything. i went too my friends house and i shifted the gears at the tranny and reverse all of a sudden started workin, and the shifter felt normal like it was with the f22. i raced all last nights and didnt miss any gears.
now today i was crusing at like 40 or so and rev matched to 2nd......i missed third. NOW if i shift real slow into 5th i can feel it grind and reverse doesnt work again.
im super ******* pissed. the swap came from hmotors and had 0 fluid in it, because of shipping purposes. i added a little over 2 qts of honda mtf before the motor was even started.
my guess is its a linkage issue. i know linkage stretches over time, but could this be my tranny going out?
Old Nov 18, 2007 | 01:30 PM
Dr.Honda's Avatar
im not being told that either my clutch master and/or slave is going out. and that its a common prob with the h series.
Old Nov 18, 2007 | 03:53 PM
Giant_Bean's Avatar
Default Re: (Dr.Honda)
sounds like the 5th gear shift fork, which is a common problem, and there actually is a Honda TSB on this issue. If you do some searching you will find more info on this issue
Old Nov 18, 2007 | 04:54 PM
Dr.Honda's Avatar
https://honda-tech.com/zerothread?id=1032769
this seems too be the same problem im having. 5th gear syncro should fix my problem correct?
Old Nov 18, 2007 | 05:11 PM
prelude_93vtec's Avatar
sounds like dr. honda is havin a problem
ya it should
Old Nov 18, 2007 | 05:30 PM
Dr.Honda's Avatar
well on the bright side, itll be like new again, and itll give me a reason too do a clutch. then ill get some mounts and ill actually be able too launch my car and put that lsd too use, lol.
i just spent $2600 and swapped the motor in myself (took 41 hours), i drive it like a granny too work all week, and cant even race it.....wTF?! lol. im so aggravated.
Old Nov 18, 2007 | 06:46 PM
Dr.Honda's Avatar
will a 5th gear syncro for a usdm h22 tranny work in my jdm m2b4?
Old Nov 18, 2007 | 06:54 PM
mgags7's Avatar
I don't know this for sure, but I don't think so, the gears are different ratios, and I believe that constitutes a different syncro.
Call up gear speed inc, they'll be able to help you out.
Old Nov 18, 2007 | 07:15 PM
Dr.Honda's Avatar
thanks man.
Old Nov 18, 2007 | 07:37 PM
Dr.Honda's Avatar
Default Re: (mgags7)
do you think it is my syncro though?-
Old Nov 25, 2007 | 02:19 AM
Dr.Honda's Avatar
well HMotors is going too completely cover everything. alls i have too do is send it back. the pay for shipping from fl - cali, fix it, and pay for shippiing back too me. im so happy.
stupid fast
Nov 22, 2012 04:21 PM
mzaner
Jul 14, 2006 07:41 AM
Apollo
Oct 5, 2003 04:39 PM
96integra20
May 18, 2003 10:16 PM
