speaker replacement help
Old Nov 17, 2007 | 07:36 AM
Grenade2k7's Avatar
Default speaker replacement help
Good Morning all!! I was wondering if anyone knew the best way to remove the door speakers in my '96 H23. Do I have to remove the entire inside of the door? Also, there is a tension bar in the trunk that does not allow me to install speakers with a bigger magnet than the stock speakers, does anyone know a way to deal with that? Thanks!!
Old Nov 17, 2007 | 08:16 AM
prelude_93vtec's Avatar
Default Re: speaker replacement help (Grenade2k7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grenade2k7 &raquo;</TD></TR><TR><TD CLASS="quote">Good Morning all!! I was wondering if anyone knew the best way to remove the door speakers in my '96 H23.</TD></TR></TABLE>
gotta take out the panel. i think you have to put the window down, take out the screws all around the panel, take out the window,door controls, the little triangle thing on the corner of the panel, and etc. and then jus pull up on it and
the speaker should be right there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grenade2k7 &raquo;</TD></TR><TR><TD CLASS="quote">lso, there is a tension bar in the trunk that does not allow me to install speakers with a bigger magnet than the stock speakers, does anyone know a way to deal with that? Thanks!! </TD></TR></TABLE>
gl with that.
Old Nov 17, 2007 | 01:34 PM
2ndlife's Avatar
Default Re: speaker replacement help (prelude_93vtec)
For the trunk, either remove the tension bar or make a spacer for the speaker so it can rest on it. But need to watch for clearance to the window.
Old Nov 17, 2007 | 01:54 PM
MLBZ521's Avatar
For the Door Speakers, there are four screws.
1) Inside the Door/Window Control Trim
2) On the Bottom Corner on the rear of the door.
3) On the Inside of the Door near the top.
4) In the Door Cup.
With a little force, you must be gentle, pull from the FRONT of the Door/Window Control Trim, it will pop out. Be careful it can break, so I don't recommend pulling from the Rear. Then Unplug the Connectors.
After remove all that, then pull on the bottom of the Door Panel. It might take a little force, but it will pop out. I can't remember if you have to take the Side Mirror Screw Covers off or not, but they just pop off if you do.. Otherwise, after pulling the Panel away from the door unhooking it, it must be pulled up as it over hangs into the window slit. I've pretty sure you can do it with the window up, but it might be easier with it down, and it will be easier with it down when reinstalling it.
The Door Speaker has three screws, remove them, and unplug it. If the speakers you have are to big, then you'll have to cut/trim the Speaker Cups so they'll fit.
For the Rear Deck Speakers, you need to get some Spacers. Go to a local Audio Store and they should have them. Just ask for Speaker Spacers, they should know what you're talking about.
And don't remove the tension bar, that makes your trunk work properly..
Old Nov 17, 2007 | 09:50 PM
BlackCatt's Avatar
Yeah, speaker spacers are the way to go.
Old Nov 18, 2007 | 03:36 AM
Lewd Nate's Avatar
Default Re: speaker replacement help (BlackCatt)
Did you already buy new speakers? From what I've been reading you need to find some thinner speakers to bolt in. I read one time what size speakers to buy, I can't seem to find the post now. I believe it was something like 6.5" X 2.2", but again, I'm not positive about the 2.2". There are some companies who make speakers in that size, but most are deeper.
If you already have the speakers, you could either buy a spacer, like someone else pointed out, or do what my previous owner did. He unclipped the tension bar and pulled it down a bit to clear the new speakers. He then wedged in some pieces of clothe between the speakers and the bar. I'm not a real fan of this, but but it does work. Although I'm not exactly pumping the power through the rears.
Old Nov 18, 2007 | 11:53 AM
Si Speed's Avatar
Default Re: speaker replacement help (2ndlife)
That's what I did.
I had to take it out when I got my back window tinted though so beware of that before you do it. Otherwise, I've not had any problems what so ever.
kornkid21792
May 23, 2009 02:38 PM
sotn10
Feb 2, 2005 09:21 PM
n0 iNTegRiTY
Audio / Security / Video
Sep 13, 2002 05:09 AM
99_SH
Feb 5, 2002 09:57 AM
mattmw88
Dec 29, 2001 11:47 PM
