Idling fluctuating, only SOMEtimes problem starting (?)
Old Nov 12, 2007 | 01:25 AM
chrisna's Avatar
Default Idling fluctuating, only SOMEtimes problem starting (?)
For the past week my automatic 1992 2.2 VTEC has been acting strange, sounds like I'm revving the car up & down when it is in neutral/PARK, when I'm nowhere NEAR the accelerator. When I put it into DRIVE it's fine again...
Also: only in this last week, have problems starting sometimes. When I turn ignition engine turns but it doesn't TAKE/FIRE. Then I leave it for 30 min or so and it starts normally again. This happens randomnly, no pattern that I can detect.
Had it at workshop, of course, murphy's law, it started etc there, didn't play up, so they could find nothing wrong.
Ideas??
Old Nov 12, 2007 | 08:33 AM
underbelly's Avatar
The Starting problem sounds like the Main Relay.
Old Nov 12, 2007 | 09:02 AM
mgags7's Avatar
Belly is right, the main relay is going out on you, that will fix the intermittent starting.
The bouncing idle is most likely due to the Fast Idle Thermal Valve, search archived threads under my name or look in the faq, I made a thread on how to diagnose these problems.
Old Nov 12, 2007 | 10:21 AM
mattsnooz's Avatar
Default Re: Idling fluctuating, only SOMEtimes problem starting (chrisna)
so the starting problems happen even after you've been driving it? Like for instance you leave, park it at a store, and when you come out it wont fire up?
Old Nov 12, 2007 | 01:33 PM
h23vtecpowered's Avatar
Default Re: Idling fluctuating, only SOMEtimes problem starting (mattsnooz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">Belly is right, the main relay is going out on you, that will fix the intermittent starting.
The bouncing idle is most likely due to the Fast Idle Thermal Valve, search archived threads under my name or look in the faq, I made a thread on how to diagnose these problems.</TD></TR></TABLE>
x2...matt helped me fix mine.
Old Nov 12, 2007 | 08:37 PM
yOnKiNaToR's Avatar
Default Re: Idling fluctuating, only SOMEtimes problem starting (h23vtecpowered)
for me, i had the crazy idle because the throttle body was letting in too much air. this confused the ecu. i tried to tighten the idle screw but it didn't make enough of an adjustment so i had to mess with the screw that allows the throttle body to sit flush with the throttle bore.
Old Nov 12, 2007 | 08:42 PM
dagle's Avatar
Default Re: Idling fluctuating, only SOMEtimes problem starting (yOnKiNaToR)
yeah, matt is the idle bounce king round here. lets all send him 's and 's
TonyTunes
11
Jan 23, 2015 01:39 PM
Victor Jónsson
Jun 27, 2013 10:01 PM
hailchristian
Dec 10, 2010 12:42 PM
Chris93Si
Aug 1, 2006 11:12 AM
cioli
11
Jun 25, 2006 11:21 AM
