shifting to reverse
Old Nov 14, 2007 | 06:18 PM
twiztid00002's Avatar
Default shifting to reverse
wen i try to shift to reverse sometimes it wont go in and i have to go to a different gear then back to reverse. any ideas to fix it?
Old Nov 14, 2007 | 06:24 PM
mgags7's Avatar
Thats just how it is. Maybe let the car roll a little as you're trying to get it in.
Note that you can't go from 5th to reverse, there is a lockout.
LunarCrusader's Avatar
Default Re: shifting to reverse (twiztid00002)
i hear this so much that i think its normal LOL although its probably not
Old Nov 14, 2007 | 07:00 PM
5thgenbb6's Avatar
Default Re: shifting to reverse (LunarCrusader)
ya, i had the same problem and still do actually.... i usually just put it as far in the reverse then rev and pull then it usually goes it. I will admit it doesnt feel very good doin it but ive been doin it since i first encountered this and it's been fine. good luck
Old Nov 14, 2007 | 07:21 PM
prelude_93vtec's Avatar
same here. 1st and reverse. what i di is if it doesnt go in, i jus slowly release the clutch and it just pops in
Old Nov 14, 2007 | 08:38 PM
liddlelude's Avatar
Default Re: shifting to reverse (prelude_93vtec)
hate to say it, but maybe that is normal. my car seems to sometimes have this "mysterious" gear that it tries to shift into instead of reverse (just doesn't go sometimes). as long as you're not grinding course mine's a 4th gen...what do i know?
Old Nov 14, 2007 | 08:56 PM
dagle's Avatar
Default Re: shifting to reverse (liddlelude)
i have this too, im almost sure its normal.. but what i do is stick it in 1st, then back into reverse.. if it doesn't happen it slides in, if it does lock me out, it feels like it goes through 2 steps. (2 separate pops) i haven't had one so stiff that i couldn't do it with my finesse shifting tho. (u know, when i have a burger in my lefthand pulling out of parking spot)
^-- yes i do that, no powersteering either.. recipe for disaster.. probably.. but i R hungy. yes hungy.
Old Nov 14, 2007 | 09:20 PM
ethereal2pt2's Avatar
Default Re: shifting to reverse (dagle)
what i find is that if i simply release and depress the clutch again and try to put it in reverse, it goes right in when this happens.
matt. you let your's roll while putting it into reverse?i thought you weren't suppose to do this. i tried this before on accident and it grinded the eff out of reverse. it's cuz it has no synchro right?
Old Nov 14, 2007 | 09:58 PM
liddlelude's Avatar
Default Re: shifting to reverse (ethereal2pt2)
grinding = bad. period.
Old Nov 14, 2007 | 10:21 PM
Selkie's Avatar
i have this problem as well.
sometimes it wont work and i have to put it back in neutral and try again
u usually can hear it get into reverse though
Old Nov 15, 2007 | 02:34 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ethereal2pt2 &raquo;</TD></TR><TR><TD CLASS="quote">matt. you let your's roll while putting it into reverse?i thought you weren't suppose to do this. i tried this before on accident and it grinded the eff out of reverse. it's cuz it has no synchro right?</TD></TR></TABLE>
Correct, no syncro.
I don't mean do it while moving at 5mph. I mean if it won't fully engage the gear let the car move some, or mess with the clutch a slight bit and it should pop in.
I don't at all mean to say that jammed or fully locked out reverse gears are normal, they're not. BUT, there is a definite problem with Prelude transmissions that causes that often.
Old Nov 15, 2007 | 03:59 AM
mattsnooz's Avatar
Default Re: shifting to reverse (Selkie)
oh, I thought that was normal for our trannies LOL
or atleast a staple.
Yeah and don't go forcing it if it won't go. As like mgags said above you could pop it into first (if possible)(or even second, but don't stall it or ur a nurd)let the car move a bit (not even a foot is needed really, the gears just need to rotate a bit as far as I know) and then go back into reverse.
It is the lockouts that are responsible for 1st and reverse correct??
Old Nov 15, 2007 | 04:06 AM
mgags7's Avatar
The only lockout is for Reverse, and it only blocks going 5th to reverse.
You can't get into first well when moving because your first gear syncro is wearing out. My current trans is a lot like that (M2S4) but my old M2F4 was butter into first, I could get into first at like 20mph with that trans.
Old Nov 15, 2007 | 10:32 AM
dreamreaperx's Avatar
i have the same thing...what i do is go as far back into reverse until it stops you, then release the clutch slightly (maybe 1/4) as im going into reverse and it'll slide right in no problems
eMbrace
May 14, 2005 07:47 AM
Civichatch2k
Jan 11, 2004 08:04 PM
tac379
17
Aug 18, 2003 06:17 PM
Paste
Sep 23, 2002 11:36 PM
mojord
13
May 21, 2002 08:08 AM
