Brake Piston
Old Nov 12, 2007 | 06:32 AM
Prelude91beginner's Avatar
Default Brake Piston
Im changing my break pads and i get the brake piston to go back in. This is my first time chaning them on this car. Is there some trick of the trade that releases the pressure so the brake piston can go back in. Thanks
Old Nov 12, 2007 | 07:16 AM
SikB's Avatar
Default Re: Brake Piston (Prelude91beginner)
Go to an auto parts store and get a caliper loaner tool set. It looks something like this http://www.harborfreight.com/c...40732 It is $35 at autozone or 90 at advanced but you get all your money back when you return it. BTW if you are doing the rears you have to turn the piston slowly while pushing it back in because of ebrake. That is where the set really comes in handy.
Old Nov 12, 2007 | 12:30 PM
mattsnooz's Avatar
Default Re: Brake Piston (SikB)
and open your brake cap. You could open the bleeder valve too I think, that should drop pressure. Remember at the end that you have to screw the piston into the caliper to get it in as far as its suppose to go to fit your rotors and pads
Old Nov 12, 2007 | 12:38 PM
ZXRider's Avatar
For the fronts you can just use a large C-clamp and push the pistons back in. For the rears you have to rotate the piston to have it go in. I was able to rotate the pistons back in using a needle nose pliers. I just put the needle nose in the grove and slowly turned.
Old Nov 13, 2007 | 07:09 AM
Default Re: Brake Piston (ZXRider)
Thanks guys! um i looked at the other rear break and i found out that one of the brake pistons are frozen.
Old Nov 13, 2007 | 07:13 AM
NirVTEC's Avatar
I bought a caliper spreader for like $5 after using a C clamp for years.
I think it was NAPA......Doing front brakes is a joke now.....
szczerbanator
May 26, 2009 05:06 PM
leviq
Jul 7, 2007 08:28 AM
funkeyone
Nov 5, 2006 09:50 AM
ForceXVII
Jan 5, 2005 02:22 PM
crxcess
Oct 9, 2002 10:50 AM
