Help? Changing a speed sensor...
Old Nov 16, 2007 | 08:55 AM
liddlelude's Avatar
Default Help? Changing a speed sensor...
Any suggestions on what tools (other than the norm) to use and/or what to remove to get to this damn thing? I was thisclose to it yesterday, but couldn't untorque the bolts cuz there's soooo much room to work. All I got was dirty and pissed off. Couldn't find any suggestions on the '93. The others are setup differently. Call me a newb but offer help if you can.
Thanks in advance!
Old Nov 16, 2007 | 08:57 AM
mgags7's Avatar
I just use a really long extension and a 10mm socket, you can get at it from the throttle body area if you take the intake tube off and just have a good 2.5' or so extension.
Old Nov 16, 2007 | 09:04 AM
liddlelude's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">I just use a really long extension and a 10mm socket, you can get at it from the throttle body area if you take the intake tube off and just have a good 2.5' or so extension.</TD></TR></TABLE>
Exactly what I thought...and did. Guess it's just breaking the torque then.
Old Nov 16, 2007 | 09:38 AM
Finest's Avatar
Default Re: (liddlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liddlelude &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly what I thought...and did. Guess it's just breaking the torque then.</TD></TR></TABLE>
It shouldn't be on there that tight.
Also, when bolting it back in, don't over tighten it either. You'll end up breaking off the tab on the VSS itself. (don't ask me how I know)
Old Nov 16, 2007 | 09:42 AM
mgags7's Avatar
^^That sucks...waste of $50....
In my experience, they're on there pretty tight from whoever messed w/it last....I don't tighten them very hard though, that bolt does nothing but hold it in....
Old Nov 16, 2007 | 09:46 AM
Hawkze_2.3's Avatar
Default Re: Help? Changing a speed sensor... (liddlelude)
Yep, loooonnngggg extension + don't break off the tab
Old Nov 16, 2007 | 10:23 AM
98vtec's Avatar
moderator emeritus
Default Re: Help? Changing a speed sensor... (Hawkze_2.3)
meh if you break the tab just use JB weld....
sivikvtec
Dec 16, 2006 05:59 AM
StraightCivic
Mar 23, 2006 08:05 AM
civic_tuned
15
Aug 29, 2005 11:31 AM
00EKjohn
Aug 24, 2005 05:44 AM
integraver
Nov 3, 2003 04:30 AM
